Need opinions..... - Mustang Evolution
Old 05-12-2011, 12:57 PM   #1
86gt's Avatar
Need opinions.....
What's everyones take on the GT-40 tube style intake, not the one that comes on explorers!? As in how they perform and how much they are worth to buy one new and used?
86gt is offline   Reply With Quote
Old 05-12-2011, 01:40 PM   #2
Re: Need opinions.....
if cheap they are a good bang for the buck.
Old 05-12-2011, 01:44 PM   #3
stampde's Avatar
the explorer intake is exactly the same as the Cobra intake ,good bang for the buck
2011 GT Auto
Old 05-12-2011, 02:03 PM   #4
86gt's Avatar
What are they worth?
Old 05-12-2011, 08:15 PM   #5
86gt's Avatar
Old 05-12-2011, 09:21 PM   #6
Titus Wadicus
svtlx's Avatar
i wouldnt give more than 300 bucks for one...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-12-2011, 09:40 PM   #7
It is a decent intake for mildly modified engines and yes, $300 for a used one is a pretty good price.
Just make sure it isn't cracked or broken anywhere.
Old 05-12-2011, 09:49 PM   #8
86gt's Avatar
Thanks!
Old 05-13-2011, 07:13 PM   #9
WhiteCobra94's Avatar
The tubed GT40 intake is discontinued but if you look on eBay you can get them used for like $400-$550 there by far one of the best intakes through the 6500rpm range it's a shame ford stopped making them!!!
Old 05-13-2011, 07:28 PM   #10
Isn't the GT40 intake basically a lightweight Cobra intake?
They use the same base.
Old 05-13-2011, 07:50 PM   #11
These is the True GT-40 tubular intake that I'm talking about! This is much better then the cobra and explor intakes!
ID:	26861   Click image for larger version
Old 05-14-2011, 07:09 AM   #12
Yep, that's it.
I read an article in one of the performance magazines that it is basically a light weight tubular version of the Cobra intake.
The only drawback to it is that it cannot be ported out to flow as much as the Cobra or Explorer manifiolds.
Old 05-14-2011, 08:40 AM   #13
Stang.racr's Avatar
Yeah and summit had them for like a 150 more thAn cobra, they where listed as same price range as holly system max which ALOT of people say it is the best stock fi intake
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-14-2011, 08:41 AM   #14
Stang.racr's Avatar
When I say stock intake I mean from the factory with no porting done
Old 05-16-2011, 06:35 AM   #15
+1 agreed!
opinions 04TRV6 Pre-2005 V6 Mustang 16 01-25-2010 08:51 AM
Looking for opinions!!!!!!! 91mustangGt 1979-1995 Mustang GT 3 08-28-2009 10:16 PM
Opinions please jimmy_beaner 1996-2004 Mustang GT 30 01-21-2009 09:19 AM
Opinions - Once and for all. OVRKILL The Bar 23 07-26-2004 04:58 PM
need opinions .:DarkEntity:. The Bar 5 08-03-2003 07:54 AM
09:50 AM
