Transmission Synchronizer - Mustang Evolution
Old 05-12-2011, 03:20 PM   #1
Qwik Four Six's Avatar
When I shift into 2nd and 4th gear, my gears scrape. I'm driving normal, shifting normal, everything. I'm guessing I need a new 2nd and 4th gear synchronizer. How much do they run?
Qwik Four Six is offline   Reply With Quote
Old 05-12-2011, 03:30 PM   #2
Re: Transmission Synchronizer
not super expensive, problem is getting them installed might as well do everything. Make SURE your clutch is adjusted right, if you are pushing the petal all the way to the floor it might not be pulling enough of the cable in~
Old 05-12-2011, 03:36 PM   #3
Yeah. If it wasn't adjusted right wouldn't it scrape in all gears?
Old 05-12-2011, 09:44 PM   #4
If the synchros are not worn equally, then it might scrape in some gears and not others. I'd make sure the clutch was properly adjusted and the cable wasn't stretched out before I rebuilt the transmission.
Old 05-13-2011, 02:06 AM   #5
Yeah. I'm probably just gonna get a world class t5 or something. What's th best transmission to get for a 5.0?
Old 05-13-2011, 06:22 AM   #6
I like the Tremec TKO's.
Old 05-14-2011, 09:23 AM   #7
86gt's Avatar
I agree with Trojan....the tremic TKO 500 and 600 are some of the best Manuel trans available for fox's!
86gt is offline   Reply With Quote
Old 05-14-2011, 09:28 AM   #8
86gt's Avatar
Unless you want to spend about $1,800 more and pick up a tremec T-56 or V-Spec T-56, the very best trans u can stuff under a fox IMO!
Old 05-14-2011, 09:31 AM   #9
+1 If money is not an issue that would be my #1 choice.
Old 05-14-2011, 11:10 AM   #10
How much?
Old 05-14-2011, 11:15 AM   #11
86gt's Avatar
$2,195
Old 05-14-2011, 04:01 PM   #12
I've seen world class T5's hold up in 10sec cars. Should be fine.
Alscobra is offline   Reply With Quote
Old 05-14-2011, 06:59 PM   #13
But a t 56 is 1800 and the tko 500 or 600 is 2200...sooo...which is better? Money is an issue though. So what about a world class t5?
Old 05-14-2011, 07:12 PM   #14
CJ ponyparts has the world class for $1296. I think maybe the 10% off and free shipping may apply also. I would just drop that in and forget about it. Anything else will cost you even more parts. Not sure if the tremec is a direct replacement.
Old 05-14-2011, 07:59 PM   #15
A WC-T5 will hold up to about 300 ft lbs of torque.
Going over that rating will eventually lead to failure.
How quickly, would be determined on how hard and how often you beat on it.
I have one in my car, which has a bit over 300 ft lbs of torque at the crankshaft and it has held up fine for a number of years.
However, knowing its limitations I don't beat on it very often or very hard.
Old 05-14-2011, 11:20 PM   #16
Stang.racr's Avatar
Transmissions are a gamble and sometimes u win, I've broke tremic 3650s with with bolt ons and heads but had good ol Borg and Warner t5 take my top end motor and sprayed car and launch away
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-14-2011, 11:24 PM   #17
Okay. I'll have 1500-2000 to play with. But not wanting to put it all into a transmission. Nothings wrong with it now besides the synchronizers. Might as well just put a different transmission in it when I decide to fix it
Old 05-14-2011, 11:26 PM   #18
Yep. The 3650 and the T56 are not very strong. Trust me, I've rebuilt quite a few t56's. I've got a buddy who's 5.0 went through 1 n2o motor and 3 more blower motors on a stock T5 and never wrecked the trans. Also barely ever used the clutch. Sold the car with a blown motor and a 150k mile stock t5 still working great.
Old 05-15-2011, 08:31 AM   #19
The Borg Warner T5 is the Tremec T5. They sold the design to Tremec a long while back.
Old 05-15-2011, 08:35 AM   #20
Here's everything you did or maybe didn't want to know about the T5 and other Tremec transmissions. They can also rebuild yours for about half the cost of a new one.
Modern Driveline
New transmission V6stang_007 Pre-2005 V6 Mustang 12 11-25-2009 04:10 PM
what transmission 67mustang97 Pre-2005 V6 Mustang 2 10-14-2009 07:44 PM
Transmission btant Pre-2005 V6 Mustang 3 01-13-2008 01:58 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
Transmission vigiracer Pre-2005 V6 Mustang 2 07-20-2003 01:47 PM
10:42 AM
