Vortech Arrived Today!!! - Page 3 - Mustang Evolution
Old 05-31-2011, 05:43 AM   #71
Send a message via Skype™ to Texastboneking
Originally Posted by 86gt
Good deal....I have to go to the doctor in Weatherford Thursday so I'll run over to Mansfield and see if they have one and if not I'll head of your way!
Ok cool
Texastboneking is offline   Reply With Quote
Old 07-15-2011, 03:03 AM   #72
86gt's Avatar
Well I'm getting a little closer to being able to drive her! It's been a long while since I took on this endeavor but I'll get it all done some day...
86gt is offline   Reply With Quote
Old 07-15-2011, 06:00 PM   #73
SleepingStang's Avatar
How did the pulley and MAF work out for you? Good luck with everything.
SleepingStang is offline   Reply With Quote
Old 07-15-2011, 06:24 PM   #74
86gt's Avatar
Exactly what I need...thanks man! I've yet to fire it up but I'm sure it'll work just fine.
Old 07-17-2011, 08:04 AM   #75
Titus Wadicus
svtlx's Avatar
Re: Vortech Arrived Today!!!
i was check'n out your pics... are you running under 6psi? im askn cause i noticed stock valve covers on your car. at sum point you may wanna upgrade to a set of valve covers that have vents/pcv on both covers. this will keep the pressure down inside the motor and reduce the amount of oil that will find it's way into your intake (common issue with s/c vehicles).
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-17-2011, 09:34 AM   #76
Stang.racr's Avatar
This along with a catch can will help big time
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-17-2011, 09:45 AM   #77
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
A vortech on a 5.0 fox is one of the most fun cars possible on the street. Congrats!
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 07-17-2011, 11:04 AM   #78
Here is a system I found on the net a while back.
I can't verify that it works because I have not installed it on my car yet, but it looks like it should work just fine.
Name:	Crankcase Ventilation-SC .jpg
Old 07-18-2011, 05:48 PM   #79
86gt's Avatar
Thanks for the info. I didn't know about that! I am going to be running low boost for now but unsure what it will be? It's a low boost kit but I have all induction pieces upgraded so it might be a little higher than 6psi. I will definitely change them when I up the pressure along with my injectors and fuel rail.
Old 07-18-2011, 11:15 PM   #80
86gt's Avatar
Thanks Trojan, I'll try that out and see if it works.
Old 07-18-2011, 11:33 PM   #81
Let us know how it works out.
Old 07-19-2011, 01:57 AM   #82
86gt's Avatar
Ten 4
Old 07-19-2011, 06:27 AM   #83
drusmith's Avatar
Send a message via Yahoo to drusmith
Good luck bro! Looks good so far!
drusmith is offline   Reply With Quote
Old 07-19-2011, 07:43 AM   #84
86gt's Avatar
Thanks man.
Old 07-19-2011, 10:23 AM   #85
Titus Wadicus
svtlx's Avatar
Thanks man.
in case the instructions dont tell u. dont hook the pcv vent tube that goes from throttle body to oil fill/vent tube on valve cover. block off tube at throttle body... leave the tube on the valve cover open/vented.
Old 07-20-2011, 12:40 AM   #86
98gtdriver's Avatar
All this talk makes ne want to get a 5oh
-Eric
98gtdriver is offline   Reply With Quote
They Have Arrived! SVTCOBRA Pre-2005 V6 Mustang 10 07-31-2010 06:11 PM
last of it arrived today :-D dark The Bar 2 08-15-2007 02:47 PM
The president has arrived! V6STANG007 The Bar 10 09-09-2004 01:38 PM
New SCT chip burned by Dennis Reinhart arrived today!! Rick0636 Pre-2005 V6 Mustang 5 02-17-2004 09:52 PM
03:15 PM
