Spark plugs and wires - Mustang Evolution
Old 05-17-2011, 04:53 PM   #1
Qwik Four Six's Avatar
I've got motorlite spark plugs in the 89. Just some new motor craft platinum ones. Ive also got 8mm plug wires. Don't think they're stock. Can't get the ratchet and socket past the header on the left and right side at the back. But I'll try to replace them soon. Opinions on the plug wires and the new plugs?
Qwik Four Six is offline   Reply With Quote
Old 05-18-2011, 08:55 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Spark plugs and wires
are those gt40 series heads? i think your gonna have to use an open end wrench to get the plug off...
motorlite???
you mean autolite or motorcraft? ive never heard of motorlite.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-18-2011, 10:16 AM   #3
motorlite???
I changed them yesterday after I posted this. And yeah, I meant autolite. But the new ones are motorcraft. It's an early 80s 5.0 that didn't come with e7 heads. I've got e7s on it.
Old 05-20-2011, 08:54 AM   #4
The wires and plugs are fine. I have ran the Autolite plugs and Motorcraft wires on several of my vehicles with no real issues from either.
If I remember correctly I had to use a swivel headed ratchet, very short extension & plug socket to get to those plugs.
Old 05-20-2011, 10:13 AM   #5
Yeah. That's what I used.
Old 05-20-2011, 10:41 AM   #6
Glad you were able to get it worked out.
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Best Spark Plugs/Wires JohnnyStang Pre-2005 V6 Mustang 19 09-15-2010 07:53 PM
Need help with spark plugs and wires! 1sweet6 Pre-2005 V6 Mustang 21 02-06-2006 12:04 AM
spark plugs and wires cms09071987 Pre-2005 V6 Mustang 5 06-19-2005 01:26 PM
spark plugs and wires romeoz Pre-2005 V6 Mustang 11 10-25-2004 02:23 PM
10:24 AM
