Distributor - Mustang Evolution
Old 05-20-2011, 10:18 AM   #1
Qwik Four Six's Avatar
Distributor
I believe it's a stock distributor on my car but if I get an msd distributor for it, what gains will I see?
Qwik Four Six is offline   Reply With Quote
Old 05-20-2011, 10:52 AM   #2
Re: Distributor
Just the distributor, probably not much.
Here is what MSD says:
"When you start making serious power with your EFI Ford, the stock distributor shaft is one of the weak links of the engine. These Pro-Billet models answer the need for an affordable replacement in a strong and great looking package. Each distributor starts as a solid billet that is secured into a state-of-the art Computer Numerical Control (CNC) machine where it is transformed into a precision housing. Inside each housing there is a sealed ball bearing at the top of the shaft. This design is responsible for accurately guiding the oversized polished steel shaft throughout the entire rpm range of your engine. The shaft is also QPQ-coated for friction reduction and corrosion resistance. The Pro-Billet Distributors use a stock-style trigger pick-up to accept factory connectors. For installation, you simply remove the stock distributor and bolt the Pro-Billet MSD in place! Each model is supplied with a high-quality cap with brass terminals for full spark delivery, heavy-duty rotor and a special gear to work with factory hydraulic roller cams."
So, you will probably realize increased reliability and more accurate timing events at the least. If your old one is worn out and sloppy, you will find a noticable improvement.
I have used several of them over the years and had no problems or issues with any of them.
Old 05-20-2011, 11:05 AM   #3
I've got a cam so I think the timing was advanced.
f**** distributor removal help forcedfed1 1979-1995 Mustang GT 6 11-20-2009 12:58 PM
Distributor Question fordman 1979-1995 Mustang GT 3 07-20-2004 12:57 PM
02:21 PM
