gt40 install - Mustang Evolution
Old 05-25-2011, 10:18 AM   #1
08v6's Avatar
gt40 install
K so I did it, gt40 upper and lower with a set of 1:7 rockkers I turn the key and it starts pissing collant and blowing white smoke, so obviously coolant is gettn in the cyl cause I didn't get the lower seated right or tourqed down enough, so now I gotta do it all over again, anyone have any tips or tricks that could help me get it right this time?
Faster Than A Speeding Ticket! Black 88 Five0, Pull Me Over Red 08v6
08v6 is offline   Reply With Quote
Old 05-25-2011, 10:26 AM   #2
stampde's Avatar
Re: gt40 install
5.0 ???? the front and rear of the cyl heads have a coolant passage , i always smeared a bead of permatex around both of these passages then put the intake gasket down over top of it ... torqued to 20 ft lbs ,starting from the center of the intake and working your way out / start with 10 ft lbs first pass then go to 20 the second pass ..... should be good to go / you probably muffed the gasket when putting the intake down ... i also used to use all thread on 2 or 4 of the bolt holes one or two on each side and lower the intake on using the all thread as dowels , then once the intake was on get some bolts in then remove the all thread and replace with your intake bolts .... finger tight ,then start your torque sequence .........
2011 GT Auto
Old 05-25-2011, 10:32 AM   #3
Re: gt40 install
Bookmarking for future reference when I do the swap when they get back from powder.
Old 05-25-2011, 06:27 PM   #4
Re: gt40 install
Be sure to change your oil and mop up any antifreeze you see in the lifter valley. It's a killer for bearings if it gets in your oiling system.
Test fit the lower and make sure it hasn't been milled down for some reason.
gt40 vs e7? GUDNEVL General Car Discussion 8 01-18-2011 10:43 AM
WTB rebuilt gt40 heads! trickflow211 1979-1995 Mustang GT 6 03-16-2009 03:57 PM
GT40 Head bolts? mattk 1979-1995 Mustang GT 2 07-11-2007 04:56 PM
Superformance Rebuilds the Original GT40 to Specs Brent General Car Discussion 9 10-17-2006 04:27 PM
GT40 cast iron heads....... Vinnietbird 1979-1995 Mustang GT 8 10-21-2005 01:45 PM
11:45 PM
