Adjustinf fuel pressure regulator? - Mustang Evolution
Old 05-27-2011, 11:20 AM   #1
How do I adjust my bbk fuel pressure regulator? It's set at 40 I need to adjust it down to 32. How do I adjust it without messing anything up?
93stang306 is offline   Reply With Quote
Old 05-27-2011, 12:49 PM   #2
Bump, taking my car to the track tonight and like to have my pressure fixed b4 I go! Thanks for any help!
Old 05-29-2011, 03:15 PM   #3
Re: Adjustinf fuel pressure regulator?
To adjust the fuel pressure, disconnect the vacuum hose and plug it off temporarily to avoid a vacuum leak.
Restart the vehicle and simply adjust the top adjustment screw in or out to raise or lower pressure to your desired reading (stock pressure is 39 psi).
Once the desired pressure is reached tighten the lock-nut and reconnect the vacuum line to the regulator.
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
EGR pics, valve cover ?, and fuel regulator hole shustwit Pre-2005 V6 Mustang 2 12-20-2009 09:23 PM
no fuel pressure ? Chasity 2005-2010 Mustang GT 12 06-30-2009 06:42 AM
holley adjustable fuel pressure regulator trickflow5 1979-1995 Mustang GT 6 01-13-2007 01:51 PM
fuel presure regulator hose? blk2kconvstang Pre-2005 V6 Mustang 0 03-07-2004 01:00 PM
04:28 AM
