91 GT shifting into 3rd at parking lot speeds (~15-20 MPH) - Mustang Evolution
Old 05-31-2011, 12:21 AM   #1
91StangGT5.0's Avatar
My 91 GT is currently shifting into 3rd way too quickly. If I am driving inside of my apartment complex it will shift into 3rd when I'm going roughly 15 MPH. My 91 LX 5.0 isn't doing this and only gets up to 2nd (unless I'm going fast enough for typical 3rd gear). The GT has 4.10s in it, so I dunno if it's the "need" of a Hi Rev Governor that is the issue...maybe TV adjustment? I've been driving it like this for a few months and I've had enough (...I know right), so I don't think the TV pressure is set too low or low enough to not have functional pressure. If I am incorrect about lower pressure causing early shifts, then possibly too high? Though, from what I've read setting the TV pressure high(er) causes later shifts as the transmission is thinking it's at WOT and the Governor has a harder time overcoming the TV Pressure.
91StangGT5.0 is offline   Reply With Quote
Old 05-31-2011, 03:52 AM   #2
Re: 91 GT shifting into 3rd at parking lot speeds (~15-20 MPH)
It is most likely cause is the 4:10 gears, but go to: clickclickforums, look up silverfox, tell him whats going on and tell 'um I sent you...
wizwrath is offline   Reply With Quote
Old 05-31-2011, 06:11 AM   #3
Send a message via Skype™ to Texastboneking
Did you replace the speedo gear to make the speedometer right?
Texastboneking is offline   Reply With Quote
Old 05-31-2011, 10:23 AM   #4
wereKEV's Avatar
texasboneking might be able to help you he is pretty knowlagable about those things.
wereKEV is offline   Reply With Quote
Old 05-31-2011, 11:05 AM   #5
I know on newer models (not positive on yours) that the transmission shifts according to your speed. If you didn't get your car programmed to run with those gears your car might think it's goin a lot faster than it really is. Therefore it will try and shift early because it thinks your going faster.
Old 05-31-2011, 11:54 AM   #6
That has nothing to do with this....shifts aren't controlled nor effected by the speedo gear.
Old 05-31-2011, 11:56 AM   #7
...I have a 91 GT dude. You don't get it "programmed". The transmission isn't computer controlled.
Old 05-31-2011, 11:58 AM   #8
Note the part where I said I'm not sure on the older models! If your going to call me out read my entire post. Otherwise stay out of it.
Old 05-31-2011, 12:01 PM   #9
your uncertainty is in the first sentence...I don't have to read the whole post. Stay out of what? This is my thread...I'm helping with your uncertainty. No need to be upset.
Old 05-31-2011, 12:04 PM   #10
My bad. I thought I was fixing to get the wrath of someone with a similar username. Lol. He always jumps on ppl when they arnt sure about something. I wasn't paying attention. anyways. Then the speedo has nothing to do with it
Old 05-31-2011, 12:17 PM   #11
No problem dude. I'm not one to immediate start bashing people. If it's wrong or if they are confused then I try to help them out.
Old 05-31-2011, 12:19 PM   #12
So what controls the shift points in your tranny. Something internal or external has to let it know it needs to shift.
Old 05-31-2011, 12:34 PM   #13
Shifts are controlled by leveling out the pressure balances of TV pressure against governor pressure. The governor is inside the tails aft housing and spins on the output shaft thus creating centrifugal force to create it's own fluid pressure to push down a shift valve. The TV pressure happens inside the transmission and puts pressure against the valve to keepthe governor pressure from moving the shift valves too easy. Once the governor spins fast enough to create the require pressure it eventually overcomes the tv pressure and pushes the shift valve inward causing a shift to happen. That's how the AOD works and I assume most other non computer controlled transmissions work the same way.
Old 05-31-2011, 12:37 PM   #14
yea for AOD you can install a shift kit but the cpu doesnt connect to it the AOD-E does (electronic)
Old 05-31-2011, 12:40 PM   #15
I remember now lol. What about that little valve on the tranny that runs to the throttle body. Could that cause your problem if that valve went bad or if the hose is no good. Because it would no longer get vacuum?
Old 05-31-2011, 02:31 PM   #16
You're talking about the TV Cable. It is set correctly. Checked it by the book many times. My thoughts would be a stuck governor or it needs a high rev governor valve since it has 4.10s
Old 05-31-2011, 02:34 PM   #17
im lost on this one. you sound like you know more anyways about the older trannies.
Old 05-31-2011, 06:18 PM   #18
Deeper gears (i.e 4.10s) cause the output shaft to spin faster than normal thus causing governor pressure to build up fast and overcome tv pressures quicker causing an early shift. As long as my foot is on the gas enough, it will shift normal. It's only happening when I drive super slow, like in a parking lot.
Old 05-31-2011, 06:24 PM   #19
well. you learn something everyday lol. let me know what you did to correct this problem. im curious now
Old 05-31-2011, 06:45 PM   #20
Will do. I have a spare Hi Rev Governor kit that I will put in sometime in the near future. Hopefully that will cure my disease.
Old 05-31-2011, 07:00 PM   #21
Beav's Avatar
You need to get one of those third pedal things, you know, I think they are called a clutch?
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 05-31-2011, 07:02 PM   #22
lol that would fix it! i knew someone would know what to do!
Old 05-31-2011, 07:11 PM   #23
Seriously.....Come on dude. Keep that **** outta here, please. I've gone through too many T5s.
Old 05-31-2011, 07:13 PM   #24
lol he was just cracking a joke until someone that knew how to fix it got on here.
Old 05-31-2011, 07:21 PM   #25
lol im trying to find a cure for you and i found your post on clickclickracing.com guess your researching hard
Old 05-31-2011, 10:07 PM   #26
86gt's Avatar
Wow
86gt is offline   Reply With Quote
Old 06-01-2011, 12:35 AM   #27
sonic04edge's Avatar
Send a message via AIM to sonic04edge
You need to calm it down man. You have been snappy more then once in this thread. Just because he was making a friendly jab doesn't mean you have to get upset about it. Your on the internet and sometimes even if people can't help you in your particular problem. They will try and lighten the mood which you apparently missed.
Now on the original topic. If you think the hi-rev governor will fix the problem. Then I suggest you give it a try instead of waiting a while. Then go from there on trouble shooting the issue.
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 06-01-2011, 05:18 AM   #28
Beav's Avatar
I got nothing against auto's... Damn, it was easy to get you going... It was a friendly remark from someone who hasn't worked on a Ford automatic since 1975 when I rebuilt a C4 in my 67 Falcon that I dropped a 351C in....
I can certainly understand running automatics if manuals wouldn't last for you.... I've pulled auto's to put in manuals for the same reason...
Old 06-01-2011, 10:35 AM   #29
wereKEV's Avatar
autos are good for some people and they are not good for other people a stick is good if you like to race and an auto is good if you like to cruise. Me I like to cruise so I have an auto ,but I also have the power to have a little fun now and then. and that is my two cents.
Old 06-01-2011, 11:52 AM   #30
stampde's Avatar
if it bothers you that much ,the early shifting , shift it manually in the parking lot
2011 GT Auto
Old 06-01-2011, 03:54 PM   #31
^^This is a wise man. If it shifts fine while out cruising around then do what he suggests until you have time to swap out the governor.
Old 06-01-2011, 04:01 PM   #32
bradh2414's Avatar
Perfect. This guys knows what he's talking about
bradh2414 is offline   Reply With Quote
parking lot fun bradh2414 General Mustang Discussion 263 06-17-2011 11:24 AM
Rant on parking lot kings... DarkShadow The Bar 55 07-12-2007 03:04 PM
rain+ new parking lot =.... Fishers Stang Pictures and Videos 9 07-15-2006 10:55 AM
Check out this zebra I saw in a parking lot!! Brent The Bar 11 03-08-2005 03:59 PM
a bit of fun in a parking lot whipster24 Pictures and Videos 5 10-03-2004 10:04 PM
04:14 AM
