Stripped Bolt! - Mustang Evolution
Old 06-04-2011, 05:31 PM   #1
nickcap's Avatar
Stripped Bolt!
Well I was taking off my caliber and the previous owner stripped the bolt somehow! How do I get it out!!! I tried vise grips and heating it with a torch, also hammering on a different size but it keeps slipping off! Anyone have any idea on how to get this bolt out! The bolt is not completely rounded but it's pretty bad!!!
Thanks
NickCap
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 06-04-2011, 06:13 PM   #2
Re: Stripped Bolt!
Thanks
NickCap
Be very careful heating with a torch. If the caliper gets hot enough it may explode.
Spray the threaded area with penetrating oil and give it ample time to work.
You might tap the end of the bolt sharply a few times.
Sometimes this will loosen them up a bit and make removal easier.
I have used a very small pipe wrench with success in the past.
Or you may just have to clamp the vise grips onto the bolt as tightly as possible and give it another go.
If you can grind or file a flat spot on two sides of the bolt head it will help you get a better grip too.
Old 06-04-2011, 06:25 PM   #3
nickcap's Avatar
Thanks I'll try when I get home! and tell you the outcome!!
wtt or sell 6 bolt aluminum flywheel for 8 bolt Everett Mustang Parts for Sale and Wanted 32 02-19-2011 09:22 PM
bolt on 3.8 3.8boii General Mustang Discussion 11 05-19-2010 07:58 PM
stripped a bolt hole on lower intake. HOw to fix? rstang Pre-2005 V6 Mustang 4 01-07-2006 08:02 AM
Stripped bolts kinda Kiljosh The Bar 11 05-30-2005 03:25 PM
w00t Engine is completely stripped and ready for machining Brent Pictures and Videos 12 05-24-2005 05:18 PM
07:34 AM
