Best way to fix a slow leaking power steering fluid - Mustang Evolution
Old 06-07-2011, 07:16 PM   #1
I keep having to refill (a little) the power steering reservoir almost every other month. Sometimes sooner. What is the best way to fix this annoying problem? Buy a new one or fix it (I have no idea how to)? Driving the Mustang today and heard the annoying whine from the power steering so I know it's time to top it off. What should I do?
Thanks!
Mike '93 LX 5.0
Mike
1993 LX 5.0
mykal302 is offline   Reply With Quote
Old 06-07-2011, 07:56 PM   #2
Send a message via Skype™ to Texastboneking
Thanks!
Mike '93 LX 5.0
Find out exactly whats leaking. Pump might be good and your gearbox might be leaking
Texastboneking is offline   Reply With Quote
Old 06-07-2011, 08:24 PM   #3
Re: Best way to fix a slow leaking power steering fluid
Agree. find what's leaking then go from there. I highly doubt your reservoir is the actual part leaking. Check the gear box (directly under the reservoir/power steering pump). They are bad about leaking out of the bottom.
Old 06-08-2011, 12:00 AM   #4
You know, underneath the steering pump it's all wet on the hoses coming out of the pump and all over that side of the steering rack. Is a bad hose(s)? Thanks for the replies too
Mike
Mike
1993 LX 5.0
Old 06-08-2011, 12:04 AM   #5
its possible. might just be the return line swelled up and is now leaking. lines will be the cheapest thing to replace so i would start there
Old 06-08-2011, 12:58 AM   #6
Stang.racr's Avatar
Red line or red seal has some power steering stop leak if you choose to take that route anyway, it's just a fluid u add to your power steering pump, I havnt seen any reviews on how good/bad it is
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-11-2011, 04:17 PM   #7
SleepingStang's Avatar
It is not uncommon for the low pressure rubber line to be forgotten about and get degraded and leak. I would replace that hose first and see if issues continue.
SleepingStang is offline   Reply With Quote
Old 06-11-2011, 06:41 PM   #8
Thanks guys. The hoses are pretty wet but I'll check with the local parts store (ford dealership better?) for a new hose. Can I just remove the old hose and install the new one or are there other steps to take?
Mike
1993 LX 5.0
Old 06-11-2011, 07:38 PM   #9
Just go to parts store and get some power steering hose of the same diameter and pull the old off and put the new on. You will lose some fluid so have a drip pan handy.
Old 06-11-2011, 07:50 PM   #10
Cool! Thanks!
Mike
1993 LX 5.0
Old 06-21-2011, 02:44 PM   #11
94 Mustang GT's Avatar
My 95 Taurus SHO had a P/S leaking problem i just put in p/s stop leak and it fixed it! Its the cheap way bu not the right way
94 Mustang GT is offline   Reply With Quote
Old 06-21-2011, 02:52 PM   #12
gqsmash's Avatar
I'd just go with a new car so you don't have to even look for the leak...
gqsmash is offline   Reply With Quote
Old 06-21-2011, 04:45 PM   #13
If it is a seal leaking the "stop leak" stuff will sometimes work, BUT this stuff works because it causes the seals to swell up...........which usually causes further problems down the road.
Old 06-21-2011, 09:32 PM   #14
+1
Power steering Snapple750 1996-2004 Mustang GT 0 04-20-2011 05:59 PM
Power Steering? NeedSomeMods Pre-2005 V6 Mustang 4 08-30-2009 01:23 AM
Power Steering? Ibanezplayer272 Pre-2005 V6 Mustang 5 11-28-2004 12:11 AM
How to: Steering Fluid Flush? cagedthought Pre-2005 V6 Mustang 2 10-24-2004 09:30 PM
Leaking Transmission Fluid?.. Ibanezplayer272 Pre-2005 V6 Mustang 20 09-07-2004 02:40 PM
03:42 AM
