86 mustang feeling. - Mustang Evolution
Old 06-08-2011, 12:20 AM   #1
86 mustang feeling.
I Was wondering if there's a way to make my 86 mustang feel a lot smoother while driving ? Any parts to change everything is stock besides my kyb struts .
Dgasca101 is offline   Reply With Quote
Old 06-08-2011, 12:57 AM   #2
Stang.racr's Avatar
Late model restoration has a shock, spring, and strut kits all together in a kit starting at 350. If your car has any vibration that makes it not run smooth then u could buy a aluminum drive shaft. Eabilch has some really good springs, And strange has some excellent adjustable shocks
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-08-2011, 08:11 AM   #3
Thanks alot man I'll be sure to change the drive shaft since my car does vibrate and getting that kit I swear I could feel every rock my car goes over haha
Old 06-08-2011, 09:50 AM   #4
wereKEV's Avatar
Re: 86 mustang feeling.
You just don't want it too smooth that rough ride to me is part of the cars personality.
wereKEV is offline   Reply With Quote
Old 06-08-2011, 09:27 PM   #5
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
It all depends on how far you wanna go.....the car is 25 years old.
I'd say rebuild the front end.....rod ends, bushings, ball joints. Fresh bushings in the rear control arms. Subframe connectors make a foxbody feel LOADS better. Fresh shocks/struts/springs.
After 25 years stuff wears out.....replace all of the stuff that is supposed to help it ride. Main additiona I'd advise is subframe connectors. They REALLY tie that chassis together.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-08-2011, 10:24 PM   #6
Titus Wadicus
svtlx's Avatar
-Will
+1
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 06-09-2011, 07:02 AM   #7
Stang.racr's Avatar
Originally Posted by svtlx
+1
+2 if you have the money to do it all
Old 06-11-2011, 04:15 PM   #8
SleepingStang's Avatar
I would go for subframe connectors also. This was the first thing I did to mine and it vastly improves the car. I also still run the 15" wheels to maintain the sleeper look. I enjoy rides in the car, no harsh jars from large wheels.
SleepingStang is offline   Reply With Quote
Clutch catching feeling jjsg09 1996-2004 Mustang GT 4 05-10-2011 10:27 AM
Clutch Feeling Sponge-like 19Delta Pre-2005 V6 Mustang 10 04-14-2009 01:07 PM
Feeling it... MarkuzLS1 The Bar 10 10-15-2007 09:30 AM
Are you feeling depressed and feel like you have no life? Seph The Bar 30 11-01-2006 12:21 PM
V8 feeling strike1980 Pre-2005 V6 Mustang 10 05-19-2006 06:22 PM
09:22 PM
