Problem getting started? - Mustang Evolution
Old 06-11-2011, 08:42 AM   #1
I've got an 89gt that I'm messing around with. Got it last summer and was starting and ran great. then I went to drive it one day, I had to hold the key over for the electronics to stay on. It kept getting worse untill it would'nt start at all. I put my new key cylinder in it this morning, fresh battery, checked all fuses and nothing but dome light and the door open dinging. I would really love to drive it! Any help please. Thanks
oojamison is offline   Reply With Quote
Old 06-11-2011, 09:09 AM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Problem getting started?
Ignition switch
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-11-2011, 09:18 AM   #3
That was next part, but the only thing that's odd is that when it started getting bad, I had to hold the key over for the motor to run and the electronics to stay on. If I let off of the key and it sprang back, everything would kick off. Then I took the key cylinder out and cleaned it, put it back in and, nothing but what I said above. Seems like a bad conection, but I thought a new cylinder would be the right answer. Just ordered an ignition switch.
Old 06-11-2011, 09:51 AM   #4
I agree it sounds like your ignition switch has failed internally.
Disconnect your battery before you replace it to make sure nothing shorts out during the replacement.
Old 06-11-2011, 09:56 AM   #5
93slowstang's Avatar
Same thing happened to me in my 93, that definitely sounds like the ignition switch.
Old 06-11-2011, 10:26 AM   #6
awsome! thanks guys.
Old 06-11-2011, 04:10 PM   #7
SleepingStang's Avatar
Just for info this was a recalled item back in the day. It would short and start the car on fire. Many of the symptoms of the recall are what you are explaining.
SleepingStang is offline   Reply With Quote
Old 06-11-2011, 08:58 PM   #8
Thanks man, Def. going to call first thing Mon. morning. This forum is GREAT!
Old 06-12-2011, 08:54 AM   #9
Now for a stupid question, where is the ignition switch located. I've looked untill I'm sick. lol I would assume it's under the dash.
Old 06-12-2011, 09:07 AM   #10
The only stupid questions are the ones you don't ask...that really get you into trouble.
The switch is connected to what you put the key lock cylinder into in the column.
I would advise that you purchase a Haynes or Chilton's manual to aide you in replacing the switch. It will also serve to help you with any future issues that may arise.
Service Manual Instructions:
Ignition Lock Cylinder
REMOVAL:
1. Disconnect the battery and air bag backup power supply.
2. Remove the two trim shrouds.
3. Remove the electrical connector from the key warning switch.
4. Turn the key to the RUN position.
5. Place a 1/8" wire or small punch in the hole in the casting surrounding the lock cylinder to depress the retaining pin in the lock cylinder while pulling on the lock cylinder to remove it from the column housing.
INSTALLATION:
1. To install the new lock cylinder, turn the key to the RUN position and depress the retaining pin. Insert the lock cylinder into its housing. Ensure the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This action will permit the cylinders retaining pin to extend into hole in the column.
2. Using the key, rotate the lock cylinder to ensure correct mechanical operation in all positions. The key release button must be used to obtain OFF and LOCK positions. Install the electrical connector for the key warning switch.
3. Check for proper start in PARK or NEUTRAL. Also ensure that the start circuit cannot be actuated in DRIVE and REVERSE and that the column is locked in the LOCK position. (They may have swapped 3 & 5 in the manual, because this would be hard to do with the battery disconnected.)
4. Install the two trim shrouds.
5. Reconnect the battery.
Ignition Switch
REMOVAL:
3. Remove the electrical connector from ignition switch.
5. Remove the 2 screws that connect the switch to the column.
6. Disengage the ignition switch from the actuator pin.
INSTALLATION:
1. Adjust the ignition switch by sliding the carrier to the RUN position. A new ignition switch should be already set to the RUN position.
2. Make sure that the key is also in the RUN position.
3. Install the ignition switch onto the actuator pin. It may be necessary to move the switch slightly back and forth to align the switch mounting holes.
4. Install the retaining screws. Tighten to 50-60 lb.-in.
5. Connect the electrical connector to the ignition switch.
6. Connect the battery. Check ignition switch for proper funtion including START and ACCESSORY positions. Also, ensure the column is locked in the LOCK position.
7. Install the two trim shrouds.
8. Connect the air bag backup power supply and battery.
Old 06-12-2011, 09:24 AM   #11
can't believe I missed it. When I hang upside down under the dash makes me sick. lol Thanks again.
Old 06-12-2011, 09:35 AM   #12
Found more information for you and posted it above.
Old 06-12-2011, 02:24 PM   #13
Got me a Haynes Repair Manual, and the breakaway bolts-do I just drill them out and use the east-out tool then put new ones in? Man, seems like alot of trouble for 2 screws.
Old 06-12-2011, 02:25 PM   #14
REMOVAL:
INSTALLATION:
Ignition Switch
REMOVAL:
INSTALLATION:
This was great info!!!
Old 06-14-2011, 01:02 PM   #15
running like a champ.
Old 06-14-2011, 01:36 PM   #16
Thanks guys, It's awsome to drive it again!!!!
Old 06-14-2011, 05:35 PM   #17
Glad to hear it.
Just started gabnmantha New Member Introductions & Greetings 11 01-16-2008 11:28 AM
trying to get something started Kyle Regional Mustang Discussion 0 08-25-2006 08:31 PM
It Started! Kiljosh The Bar 3 06-11-2006 12:05 PM
who started STEVE The Bar 19 06-16-2004 01:34 PM
getting started dansmustang 1996-2004 Mustang GT 2 04-19-2004 12:59 PM
05:25 PM
