Heads - Mustang Evolution
Old 06-12-2011, 07:59 PM   #1
Heads
What heads are on a stock 1979 302??? And would a set of D80eab 351w heads ''which I believe are 1978'' give me any more horse
Z06 eater is offline   Reply With Quote
Old 06-12-2011, 09:48 PM   #2
93slowstang's Avatar
351 / 78-80 / D8OE-AB / 69CC / 1.78/1.45
302 / 79-84 / D9AE-AA / 67.5-70CC / 1.78/1.46
I don't believe those would give you any performance gains.
Old 06-12-2011, 09:54 PM   #3
Re: Heads
I agree.
The C9-OE or D0-OE 351W heads fitted with larger valves (1.94/1.60) and some porting work used to be the hot ticket in the day.
Nowadays you are better off and money ahead to save what you might spend doing that and invest that money in a good set of aluminum heads.
You will get much better flow characteristics and lose a bit of weight off the front to boot.
Old 06-12-2011, 09:58 PM   #4
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Heads
My advice, if you want the best option for a stock casting 302 head, is to go with some hand ported E7's.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-12-2011, 10:14 PM   #5
Originally Posted by Trojan Horse
I agree.
+1
Old 06-12-2011, 10:15 PM   #6
Re: Heads
If aluminum heads are an option, do it....
-Will
Waffles
Old 06-13-2011, 03:08 PM   #7
What heads are in my 89 gt? Would those b e7's?
Old 06-13-2011, 03:31 PM   #8
Yes those should be e7's
Old 06-13-2011, 03:40 PM   #9
Ok Kool what about gt40p heads would they give me a Lil more power on my 79
Old 06-13-2011, 04:49 PM   #10
Re: Heads
What kind of power level are you wanting to achieve?
As an example I believe the Holley Systemax Kit (HCI) will net you around 350 HP at the flywheel.
Maybe you could use those part specs as a guide to build your own kit at a higher or lower HP level?
I'd choose the AFR 165 or 185's over the GT40p's.
Old 06-13-2011, 06:01 PM   #11
Re: Heads
Avoid P heads. They actually flow pretty good, but headers for them are head specific and hard to find in the classifieds...
-Will
Waffles
Old 06-13-2011, 06:14 PM   #12
I'm running gt40 p heads right now with bbk shorties. It is a little tight and requires some finesse to change plugs but it was still definitely worth putting on those heads to me. Besides if headers are in your budget frp's headers are fairly inexpensive.
3.8 Heads kirbo7106 Pre-2005 V6 Mustang 5 01-28-2011 10:12 PM
heads upton7 1996-2004 Mustang GT 3 09-22-2009 11:21 PM
how can i tell if i have PI heads or not? redbird2289 1996-2004 Mustang GT 4 08-26-2009 08:56 PM
need help with heads johnnyc 1996-2004 Mustang GT 2 06-08-2009 01:15 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
10:41 AM
