What gears? - Mustang Evolution
Old 06-13-2011, 08:11 PM   #1
mustangbill00's Avatar
What gears?
Ok here's what I have...95 GT vert with a rebuilt T5, fresh motor out of an 83gt bored 30 over but has 95 heads and stock EFI setup, UD pulleys, BBK equal length headers going into an O/R X pipe and Flowmasters. The cam is a custom grind from Comp Cams but the guy I got the car from lost the spec sheet. He thinks it was 52? Intake and 514 exhaust, not on the rest. I got the numbers off the cam but I just gotta get ahold of comp cams for the numbers.
The car came with a set of 4:10s ( not installed ) but I'm wondering if that is to much. Should I ditch them and get 3:73s or maybe even 3:55s? This is just such an odd motor combination and I'm just not sure what to do with it. Is it ok to run the non-roller block with the EFI? What are the drawbacks with a non-roller?
mustangbill00 is offline   Reply With Quote
Old 06-13-2011, 08:21 PM   #2
410 is fine my gf has them in her 94 gt with UD pullies cai new clutch steeda shifter lol and it's her DD it's fine. I think
93stang306 is offline   Reply With Quote
Old 06-13-2011, 08:31 PM   #3
Re: What gears?
The 94 up Mustangs are heavy. I would use the 4.10's.
Are you sure the block wasn't converted to a roller block?
It is ok to run a non roller block. The roller set up is just more efficient and with less valve train friction too, it will help produce a bit more power and less wear.
Old 06-13-2011, 08:37 PM   #4
I pulled the intake off and checked and it does not have the conversion. I thought about converting it to a roller but I was told that there a limited number of cams to choose from.
Old 06-13-2011, 08:38 PM   #5
BTW thanks for the quick response everyone!
Old 06-13-2011, 08:44 PM   #6
Re: What gears?
That's not true. There are lots of choices and you can always get a custom grind.
Check this out - CamQuest
Old 06-13-2011, 09:04 PM   #7
Who makes a good affordable conversion kit? What kind of hp would I gain from making this switch?
Old 06-13-2011, 09:25 PM   #8
Re: What gears?
Maybe 5-20 HP.
Roller Lifter Conversion
Old 06-13-2011, 09:44 PM   #9
Las0mbra's Avatar
Originally Posted by Trojan Horse
That's freakin cheap!
Old 06-13-2011, 09:49 PM   #10
Re: What gears?
Yes it is. To cheap to not do the conversion.
Old 06-13-2011, 09:51 PM   #11
Las0mbra's Avatar
I agree, for 3 horsepower that seems worth it. Performance parts are expensive.
Old 06-13-2011, 09:53 PM   #12
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: What gears?
I'd advise 3.73's or 3.90's. 4.10's are a bit much for a 5.0 car that is regularly driven. They don't make power as high in the RPM's as modulars, and their gas mileage quickly diminishes with RPM.
4.10's WOULD make it quicker at the track....but 3.73's would probably be a better all around gear
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-13-2011, 10:03 PM   #13
The kit is cheap BUT you gotta factor in new lifters, pushrods and a new roller cam. Not saying I won't do it, I'm just saying there's a little more to it than just the $50 kit, and I also think I would have to change my distributer gear to match the roller cam....I think.
Old 06-13-2011, 10:05 PM   #14
Las0mbra's Avatar
I know you have too, but if you get a new cam, you'll get better gains anyway
Old 06-13-2011, 10:06 PM   #15
Re: What gears?
Dist. gear will have to be changed. If not done, bigger problems will happen....
My advice would be to go with a TFS stage 1 cam, find one used or something.
If you're going to do all of that, there is NO reason not to upgrade the rockers arms.
-Will
Waffles
Old 06-13-2011, 10:10 PM   #16
@knight. It will only get driven on weekends so I'm not too worried gas mileage. I think I will try the 4:10s out and if I don't like them I will throw in some 3:73s. No biggie
Old 06-13-2011, 10:17 PM   #17
Well guys I'm having a hard time keeping my eyes open so it's off to bed for me. I'm on my iPod and the ME app does not have the "thanks" option so I will be sure to hit everyone up first thing in the morning. Nite all
Old 06-13-2011, 10:19 PM   #18
Re: What gears?
If that's the case, you'll love the 4.10's.
Especially due to your setup, you need to find out where your power falls off. If you have a local dyno around there, I say you get a pull. Seeing the power curve would do you some good.
The car will rev pretty quick....you want to make sure you don't hold it out into RPM's after you've peaked
-Will
Waffles
Old 06-13-2011, 10:25 PM   #19
Lol your killing me! There is a shop about 40 miles from me with a dyno. I'm sure it also needs a tune too
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
4:10 gears? The Darkside Pre-2005 V6 Mustang 33 12-06-2008 09:16 PM
3.73 gears fasternu_674 Pre-2005 V6 Mustang 20 05-11-2008 04:35 PM
new gears strike1980 Pre-2005 V6 Mustang 10 06-26-2005 06:09 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
» Members Mustangs
ANGIE
BC13
booger
moid316
Add your Mustang
08:11 AM
