need help - Mustang Evolution
Old 06-13-2011, 10:24 PM   #1
Region: Arkansas
need help
Originally Posted by ponyexpress
I have a 1988 Mustang GT with Ho302 5 speed. It was running then just shut down. Checked timing, firing. Need advise to what could be making my car not run. Has new computer, new fuel rail and injectors, new fuel pump, new fuel relay, new plugs and wires, new starter, new fuel regulator, new coil and new tfi sensor. And still nothing put on scanner no codes showed up. I've got raw fuel coming out my spark plug. It ran for a minute then shut off and has not started since.
ponyexpress is offline   Reply With Quote
Old 06-13-2011, 10:31 PM   #2
Re: need help
Sounds like you may possibly have injectors stuck open.
Have you checked your fuel pressure?
Are you sure the timing is correct?
The timing chain may have failed.
Make sure you have fire to the plugs?
Old 06-13-2011, 10:36 PM   #3
Region: Arkansas
Re: need help
I've checked the fuel pressure and timing is correct. Maybe injector.. I'll check that. I did replace injectors. hmmm? Let you know if thats problem.
Old 06-13-2011, 10:44 PM   #4
Re: need help
Check all of your ground wires to ensure they have a good connection.
Especially the computer and engine grounds.
Old 06-13-2011, 10:55 PM   #5
Region: Arkansas
Re: need help
I checked ground wires today all were good. 3 of the plugs I pulled I had raw fuel and you could tell plugs were not firing, the wires had fire but plugs none.
Old 06-13-2011, 11:04 PM   #6
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: need help
If you have a spare TFI module, test it out.
Pull the dist. cap and make sure all is well in there.
It's pretty much impossible for your wires to get spark but your plugs to get none.....it's more likely that they're just not firing at the right time.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-13-2011, 11:09 PM   #7
Region: Arkansas
Re: need help
Already replaced TFI module. New rotor as well.. After it sets a day it will start then nothing.
Old 06-13-2011, 11:14 PM   #8
Re: need help
If you know anybody with a spare fuel pressure regulator, swap them out and see if that fixes it.
Also, get a test light or multimeter and find out if the injectors are pulsing properly.
-Will
Waffles
Old 06-13-2011, 11:24 PM   #9
Region: Arkansas
Re: need help
I got a spare fuel pressure regulator I'll swap it out.
Old 06-14-2011, 10:20 AM   #10
Greg687's Avatar
Region: New Mexico
Re: need help
Well, right now it sounds like it's flooded. Raw fuel is too rich to burn, so even if you do get spark it won't ignite. While you are doing all of this pull the plugs and let the cylinders dry out.
If it's that flooded, make sure you didn't get gas in the oil. Pull the stick and give it a sniff. Raw gas can slip past the rings and dilute the oil, which is bad. If it happens change the oil before you run it any length of time.
Greg687 is offline   Reply With Quote
Old 06-14-2011, 10:42 AM   #11
wereKEV's Avatar
Re: need help
Also check the fuel pump shut off switch in the trunk it could have to be reset.
wereKEV is offline   Reply With Quote
Old 06-14-2011, 11:34 AM   #12
86gt's Avatar
Is it turning over but not starting or is it not doing anything? If it's not doing anything make sure to connector is tight to the computer and if it is turning over and your getting spark to the plugs and you say the timing is correct...double check to make sure that it is wired in the right firing order!!!
86gt is offline   Reply With Quote
Old 06-17-2011, 01:43 PM   #13
Region: Arkansas
Re: need help
I can not get my mustang to idle hot start or cold start. I changed the tps and still will not set and idle. I can take the screws out of tps and turn it by hand and yes it will idle but its not idling when i put screws back in because its not wanting to stay set where it needs too. Any suggestions.
Old 06-17-2011, 01:46 PM   #14
Send a message via Skype™ to Texastboneking
Ok. Sounds funny but I know on the older cars that if the temp sensor went out the car would barely run. Have you checked that?
Texastboneking is offline   Reply With Quote
Old 06-17-2011, 01:49 PM   #15
Re: need help
Has the engine been converted to MAF or is it a Speed Density ECU?
Old 06-17-2011, 01:49 PM   #16
Region: Arkansas
Re: need help
I have replaced every sensor on this car. I can get her to run as long as I am holding tps and turning it but as soon as I let it go it over she dies.
Old 06-17-2011, 01:50 PM   #17
Need a new tps?
Old 06-17-2011, 01:50 PM   #18
Region: Arkansas
Re: need help
MAF and I have replaced this as well.
Old 06-17-2011, 01:51 PM   #19
Region: Arkansas
Re: need help
I Just bought this one and put it on today.
Old 06-17-2011, 01:52 PM   #20
Might just have too much resistance in the wires running to the tps. Check the harness for corrosion
Old 06-17-2011, 01:54 PM   #21
Region: Arkansas
Re: need help
No corrosion.
Old 06-17-2011, 01:55 PM   #22
No corrosion.
Is the adjustment screw on the throttle body closed too much? Idk what else there really is to check. If you've replaced all sensors
Old 06-17-2011, 01:59 PM   #23
Region: Arkansas
Re: need help
I was wondering the same thing. I will check that and get back with you thanks
Old 06-17-2011, 02:01 PM   #24
No problem. Hopefully that's what it is
Old 06-17-2011, 02:34 PM   #25
Re: need help
You cannot just indiscriminately turn screws and twist components.
There is a procedure to follow when you are setting the idle.
Do you have a manual for the car that shows the procedure??
Old 06-17-2011, 02:58 PM   #26
I might can get one. He can adjust it and if the idle improves then he knows that may be the problem. But I'm pretty sure he will need a computer to do this accurately. An the old diagnostic hookup is not a common thing he might have.
Old 06-17-2011, 03:09 PM   #27
Re: need help
He's a she. .. and I salute you ponyexpress.
Not many females will attempt to work on their vehicles.
I taught all of my daughters the basics and they work on their own vehicles now.
Shouldn't need a computer to set the idle, should she?
I never used one on my 86, 89 or 95.
I'm sure I have a manual with the procedure, but my scanner is busted.
Old 06-17-2011, 03:13 PM   #28
Shouldn't need a computer to set the idle?
I guess I'm not thinking old enough. On the cars I've worked on you had to be connected to the computer to watch tps voltage while setting the screw for idle. Not sure about the older cars that's why I said he might need to be connected.
Now see if I'm right. If he goes and buys a new throttle body it should be set to the right spot right?
Old 06-17-2011, 03:15 PM   #29
Re: need help
On a fox you use a multi-meter voltage tester.
A new one won't necessarily be correct, just like a new carb should always be tuned.
Old 06-17-2011, 03:27 PM   #30
Hmm good to know
Old 06-17-2011, 03:28 PM   #31
93slowstang's Avatar
Here is a link on how to reset the base idle so we don't have to type all the info...
http://www.moddedmustangs.com/forums...dle-reset.html
Old 06-17-2011, 03:29 PM   #32
Re: need help
5.0 Base Idle Reset
lol where the heck did you come from??? good find though
Old 06-17-2011, 04:14 PM   #33
I came from here...lol. I saved that link from when I did my h/c/i and tb.
Old 06-17-2011, 04:37 PM   #34
Region: Arkansas
Re: need help
Its not the screw.. I am a she and thanks. Still not idling. I put it on scanner no codes show. It has to do with that tps I put it on nothing take screws out of the tps and turn tps to open throttle by hand and it will run of course at high rpms. Out of options....
Old 06-17-2011, 04:39 PM   #35
Region: Arkansas
Re: need help
I used a digital multimeter shows 1v which is okay considering it's a HO302.
08:34 AM
