Auto to manual - Mustang Evolution
Old 06-14-2011, 11:31 AM   #1
91gt's Avatar
Auto to manual
I was just wondering what's all involved in swapping an auto to a stick the guy I bought it from put the pedal in all ready and I got to push it in to start it
91gt is offline   Reply With Quote
Old 06-14-2011, 11:33 AM   #2
Send a message via Skype™ to Texastboneking
91 model??? Not much really. Shouldn't need a PCM reprogram or anything. The older year is pretty much plug and play if I remember right.
Texastboneking is offline   Reply With Quote
Old 06-14-2011, 12:05 PM   #3
93slowstang's Avatar
+1, the aod PCM will work just fine with no problems. Like Texas said it's all plug and play except for the speedo gear at the end of the speedometer cable that go's into the tranny.
Old 06-14-2011, 12:08 PM   #4
+1. Forgot about the speedo gear
Old 06-14-2011, 02:30 PM   #5
Re: Auto to manual
you need more than just trans parts though, like wiring harness for the back end of the car~
Old 06-14-2011, 03:33 PM   #6
That's only if he wants to run the a9l ecu. If he uses the aod ecu that's already in the car he won't need to add the harness.
Old 06-14-2011, 06:41 PM   #7
Here's a link that should give you most of what you need to know
http://ponyforums.com/fox-body-musta...onversion.html
Old 06-14-2011, 06:46 PM   #8
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Auto to manual
You'll need the trans, shifter, cross member & trans mount, clutch/pp/flywheel, speedo gear, and a clutch cable. Get a firewall adjuster too. It'd also be nice if you could locate the bracket that bolts up to the cylinder head that holds the clutch cable out of the way.
You may be able to use/modify that cross member....not sure.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Auto to Manual The Darkside Pre-2005 V6 Mustang 9 10-30-2009 12:23 PM
auto vs. manual occhopperman27 1996-2004 Mustang GT 6 09-15-2009 01:24 PM
Auto vs Manual Justin 1979-1995 Mustang GT 18 10-19-2006 08:49 PM
3.8 auto vs manual megax29 Pre-2005 V6 Mustang 14 10-24-2004 10:43 AM
auto or manual? oaktonarcher The Bar 31 06-07-2004 12:39 PM
07:52 PM
