can't push gas pedal in more than half way help - Mustang Evolution
Old 06-14-2011, 11:36 PM   #1
95 gt guy's Avatar
My 95 gt has a problem if I push the pedal in more than half way it sputters and looses power
95 gt guy is offline   Reply With Quote
Old 06-14-2011, 11:47 PM   #2
Pete07GT's Avatar
Send a message via ICQ to Pete07GT Send a message via AIM to Pete07GT Send a message via Yahoo to Pete07GT
Bummer, a castrated GT is a big no bueno amigo.
When you're going to war, you better have three things if you expect to win: 1. Willpower (One's need to put the petal to the metal); 2. Staying Power (300+ BHP); and 3. Firepower (The wheels of your mustang exploding on the highway like a slug from a .45).
Pete07GT is offline   Reply With Quote
Old 06-14-2011, 11:49 PM   #3
95 gt guy's Avatar
What are some solutions???
Old 06-14-2011, 11:53 PM   #4
Las0mbra's Avatar
Maybe a fuel problem?
Old 06-14-2011, 11:55 PM   #5
Pete07GT's Avatar
I had that problem when my fuel pump was going out. Possibly throttle body? Ill bet someone will post with a probable solution as time goes by.
Old 06-14-2011, 11:58 PM   #6
95 gt guy's Avatar
I've changed air filter and fuel pump and fuel filter???
Old 06-14-2011, 11:59 PM   #7
Pete07GT's Avatar
Damn, I'm stumped. Check the CP2 sensor?
Old 06-15-2011, 12:16 AM   #8
95 gt guy's Avatar
I'll do that and going to get new o2 sensors because there brownish
Old 06-15-2011, 12:28 AM   #9
95 gt guy's Avatar
I know you sent something but its not showing it so send it again
Old 06-15-2011, 12:43 AM   #10
93slowstang's Avatar
Make sure none of your plug wires are arching out. If they are grounding out it will cause those symptoms.
Old 06-15-2011, 12:54 AM   #11
95 gt guy's Avatar
K thanks ill try it as soon as I can
Old 06-15-2011, 12:59 AM   #12
Right now would be the best time if possible. If not just wait till it gets dark pop the hood, crank it and see if it looks like a christmas tree...
Old 06-15-2011, 02:41 AM   #13
95 gt guy's Avatar
Ok thanks but ill do it later because I'm at my grandpas house and its at my house
Old 06-15-2011, 06:54 AM   #14
Re: can't push gas pedal in more than half way help
yea you ever change your fuel filter?
Old 06-15-2011, 07:04 AM   #15
Stang.racr's Avatar
Check your timing
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-15-2011, 07:06 AM   #16
Send a message via Skype™ to Texastboneking
Umm.. How come no one has mentioned checking the maf sensor???
Texastboneking is offline   Reply With Quote
Old 06-15-2011, 08:44 AM   #17
mustangbill00's Avatar
I was just going to mention that! I had a similar problem when my MAF was dirty from over oiling the air filter. Try cleaning the sensor wires inside, it's free and easy to do.
mustangbill00 is offline   Reply With Quote
Old 06-15-2011, 08:48 AM   #18
There we go! I figured this was an obvious thing to check! Get some maf cleaner and spray the resistor inside the mad. That will most likely fix your problem.
Old 06-15-2011, 05:44 PM   #19
95 gt guy's Avatar
Ok thanks
Old 06-15-2011, 05:48 PM   #20
Get a Haynes or Chilton's manual for your car.
Test the IAC and TPS.
Check your fuel pressure.
The regulator may be bad and not supplying enough fuel.
Old 06-15-2011, 05:51 PM   #21
95 gt guy's Avatar
K thanks but have already replaced fuel filter and pump
Old 06-15-2011, 05:57 PM   #22
I saw that in your earlier post, but it won't help if the pressure regulator is bad. That's why you need to verify that you have the correct fuel pressure.
Old 06-15-2011, 05:59 PM   #23
95 gt guy's Avatar
Ok I will do that as soon as I can
Old 06-15-2011, 06:36 PM   #24
bigcolt45's Avatar
Texas is right I am an ase mechanic and my money is that your mass air flow is dirty or bad .... But mostly dirty and leave your 02 sensors alone....... Your throttle position would throw a code .... So clean mass air flow and in hook your battery terminals and touch the wires together than reinstall them and it should be fine
bigcolt45 is offline   Reply With Quote
Old 06-15-2011, 06:39 PM   #25
95 gt guy's Avatar
I cleaned it already
Old 06-15-2011, 07:10 PM   #26
bigcolt45's Avatar
Than replace it
Old 06-15-2011, 07:11 PM   #27
Did it help?
Old 06-15-2011, 07:13 PM   #28
95 gt guy's Avatar
It has just been replaced and it helped a little but now I'm back where it started out
Old 06-15-2011, 07:41 PM   #29
bigcolt45's Avatar
Did you reset the PCM??? The battery terminal thing I mentioned ??? So it can relearn
Old 06-15-2011, 08:58 PM   #30
im not trying to sound rude. but ase dont mean much... anyone can read a book and pass a written test. you can get an ase without ever touching a car. like i said im not trying to be rude but help you realize that. the ford dealer i work at dont care if your ase certified. you have to be ford certified. they told me that my ase meant absolutely nothing to them... all they car about is ford certification. dont take this post wrong
Old 06-15-2011, 09:00 PM   #31
well if that didnt do it, look at the fuel regulator like Trojan suggested. no check engine light???
Old 06-15-2011, 09:50 PM   #32
95 gt guy's Avatar
It comes on and off but ill check it
Old 06-16-2011, 05:51 AM   #33
bigcolt45's Avatar
Oh I don't get easily offended ... I have been working at an independent shop for more than ten years and just recently got my wall trophies ..... I just hate when I see some people on here throwing the person into all directions and I try to throw in my two cents when I can ..... I know you have an automotive back ground by the things you post and the intelligence in your diag input ..... And that is all I am on here for is I love working on cars and trying to give a lead tech opinion on troubles people are having
Old 06-16-2011, 05:54 AM   #34
Cool. I knew you had some experience yourself. Just couldn't tell how much. You've been at it longer than I have though. I just thought it was weird when the dealer told me ase doesn't mean anything to them...
Old 06-16-2011, 08:47 AM   #35
Stay on topic.
Please Help!! Whistling when pressing gas pedal Killabeez26 2011-2014 Mustang GT 35 08-08-2011 07:35 AM
New gas pedal assembly (warranty) Lastoria24 1996-2004 Mustang GT 0 05-24-2011 11:18 AM
Half Human, Half Tree Brent Pictures and Videos 11 11-26-2007 10:01 AM
Finally did the gas pedal mod !!! Danger Dude Pre-2005 V6 Mustang 55 09-11-2004 08:34 PM
Gas pedal fix OR_Red98 Pre-2005 V6 Mustang 2 08-18-2003 06:59 PM
09:30 PM
