A/C Help! - Mustang Evolution
Old 06-19-2011, 07:57 PM   #1
nickcap's Avatar
A/C Help!
hey guys,
ok well i bought a car with no a/c!! its a 1995 mustang gt convertible! i need to know the oarts i need, i was told i need to replace everything, and there is no a/c compressor in the car, it has a delete wheel! i just got a brand new a/c compressor, but i need everything else! i do not know what to get! i dont even have the lines?!? so, im asking, what parts do i need beside the a/c compressor to have working air and where can i find cheap deals!?!
thanks
nickcap
nickcap is offline   Reply With Quote
Old 06-19-2011, 08:14 PM   #2
Las0mbra's Avatar
Originally Posted by nickcap
hey guys,
thanks
nickcap
Probably the easiest/cheapest way would be to use a donor car. Don't really know what parts you'd need though...
Old 06-19-2011, 09:06 PM   #3
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: A/C Help!
It all depends on what may have been left on the car....you'll need compressor, evaporator core, condenser, lines, dryer, and switches/relays/sensors.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-19-2011, 09:11 PM   #4
Re: A/C Help!
Sorry, but cheap & A/C parts just don't go together.
If you buy cheap/used parts you will probably end up spending more than new parts would have cost trying to get everything to work.
The donor car idea is your best bet, but make sure the A/C is/was working properly before you buy and replace all seals or hoses to ensure your refrigerant stays in the system.
Old 06-19-2011, 09:13 PM   #5
Re: A/C Help!
If you get used parts make sure to have them flushed.
-Will
Waffles
Old 06-19-2011, 09:27 PM   #6
nickcap's Avatar
Thanks guys
1995 Mustang GT Convertible!! (My Baby Monique) Ha
Old 06-19-2011, 09:43 PM   #7
nickcap's Avatar
So like napa I should go to or?
Old 06-19-2011, 10:07 PM   #8
Re: A/C Help!
I think it would be best if you went to see a qualified A/C repair mechanic.
They can look at your car to see what is missing and what you will need to replace and give you a parts list.
Old 06-20-2011, 02:03 AM   #9
86gt's Avatar
If everything was removed, I would look it to a full kit from Late Model Restoration! It pretty high but as was said earlier it's never cheap when it comes to A/C's!
If you go with a donor and depending on if the system was open or not you are gonna want to replace the dryer with a new part and it's always best to replace the hoses! I personally don't recommend using a donor car cuz you never know what you're getting unless you know first hand that the A/C was in working condition before the swap! If I'm not mistaken, If a system was left open for even a day you have to replace all the seals and the dryer because moisture from the atmosphere completely ruins them
86gt is offline   Reply With Quote
Old 06-20-2011, 10:50 AM   #10
nickcap's Avatar
Yea thanks guys
Old 06-21-2011, 03:16 PM   #11
94 Mustang GT's Avatar
Re: A/C Help!
Go ask someone that knows about A/C to see what you have, get what you doont have and FLUSH it out when you get it togeter! Make sure its a GOOD FLUSH though!
94 Mustang GT is offline   Reply With Quote
Old 06-21-2011, 03:17 PM   #12
gqsmash's Avatar
Shoot just rig up a window unit like you see sometimes on vans!!!
gqsmash is offline   Reply With Quote
Old 06-21-2011, 03:18 PM   #13
Re: A/C Help!
you can probably find a 5.0 at a junk yard~ well maybe so lol but as said the parts need to be cleaned out good
Old 06-22-2011, 10:48 AM   #14
nickcap's Avatar
Thanks guys!!
06:26 PM
