94 mustang gt tach problem? - Mustang Evolution
Old 06-20-2011, 04:20 PM   #1
My girlfriends 94 mustangs tach is acting weird. We pulled the instrument cluster everything has good connection there. But for some reason the tach doesn't work 90% of the time, and then sometimes it does. What could be the problem? How do I fix this, if it's working at all then it's gotta be a bad connection I would think but I don't know where the wires go or anything
93stang306 is offline   Reply With Quote
Old 06-20-2011, 05:26 PM   #2
Re: 94 mustang gt tach problem?
Buy a Haynes or Chilton's manual with the wiring diagrams and trace out the wiring.
If it is intermittant like that either you have a bad connection or the tach itself is failing.
Old 06-20-2011, 07:24 PM   #3
jhagan1980's Avatar
Mine is doing the same exact thing.
jhagan1980 is offline   Reply With Quote
Old 06-21-2011, 03:40 AM   #4
Guys, is it just the tach or are other accessories acting up?
I ask because it could be symptoms of a bad ignition switch contact.
Old 06-21-2011, 08:54 AM   #5
jhagan1980's Avatar
I haven't noticed anything else acting strange.
Old 06-21-2011, 09:35 AM   #6
Ok, probably in the tach or wiring then.
Old 06-21-2011, 02:00 PM   #7
94 Mustang GT's Avatar
My temp gausge will incress as my electrical load increases. When i used to have subs and they would hitg my temp gauge would incress. But i have taken a temp gun to the engine many times and is always at where it should be around 190 200, a few other of my gauges will flutter (battergauge once in a while and oil gauge rarerly but will flutter a little)
You think it could be bad ign contact? Or something else?
94 Mustang GT is offline   Reply With Quote
Old 06-21-2011, 05:23 PM   #8
Yes, that would be possible.
Did you have a noise filter installed on power wire to the stereo system?
If not, that may have been the cause of the flutter or it could have just been from the sound wave presssure from the subs.
The voltage gauge flutter would lead me to suspect an intermittant contact that may or may not be the ignition switch.
I would also check your grounds, specifically at the engine and ECU.
Old 06-24-2011, 03:36 PM   #9
jhagan1980's Avatar
On the way to work tonight I got to looking at my dash and noticed my needle is actually past zero. It's on the opposite side of the little stopper by the zero.
Old 06-24-2011, 09:24 PM   #10
You could try removing the tach and cover, then gently lift the needle back to the correct side of the stop. Then see if it will work or not.
It is very likely that the tach is defunct though.
I wonder how it got there?
I wonder if it went completely around or bounced past the stop during engine shut down?
Old 06-24-2011, 09:31 PM   #11
jhagan1980's Avatar
Well it was messed up to begin with but I think it jumped it. Is it very hard to change it out and where would I get a new one besides a junk yard?
Old 06-24-2011, 10:01 PM   #12
mustangbill00's Avatar
Auto Meter
mustangbill00 is offline   Reply With Quote
Old 06-24-2011, 10:08 PM   #13
jhagan1980's Avatar
Is that an in dash one? I already have a tach on my steering column but I'd like to get the factory one to work as well
Old 06-24-2011, 10:13 PM   #14
I've never changed one, but I don't think it would be to difficult.
Disconnect the battery, pull the cluster out of the dash, then remove the tach?
Here is a tach pinout that will help you test it.
Name:	95 Mustang Tach Pinout.gif
Old 06-24-2011, 10:31 PM   #15
I think the cluster is all one piece. I pulled mine out a while back to clean out the Inside and I think it's all one piece. Don't quote me on that because it was a while back. The cluster came out easy tho.
Tach not working crusty103 2005-2010 V6 Mustang 1 06-18-2011 12:16 AM
tach ? gearbanger67 Classic Mustangs 4 04-14-2007 07:06 PM
tach problem cash05_mustang Pre-2005 V6 Mustang 4 10-18-2006 06:16 PM
Installed Tach 98 Gt SilverStang96 1996-2004 Mustang GT 11 02-19-2006 12:08 AM
Tach not working... SilverStang96 Pre-2005 V6 Mustang 3 11-12-2004 11:34 AM
08:20 PM
