Paint?? - Mustang Evolution
Old 06-20-2011, 10:30 PM   #1
nickcap's Avatar
Paint??
Hey guys
Tomorrow I want to take off the upper intake manifold to clean it and paint it! I have never done this before, but the painting part is going to be done by my buddy who paints for a living! So, how do I take it off? Anything I need to worry about? I heard that there are a couple bolts? Should I clean anything Like the TB while I'm cleaning the manifold? Thanks for all of your help and u would greatly appreciate opinions and help on what to do!!!
Thanks
Nickcap
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 06-21-2011, 02:23 AM   #2
SleepingStang's Avatar
Best thing to do is get a Haynes or Chilton manual so you have torque settings on assembly. Removing is pretty straight forward. Remove intake piping, throttle body and spacer, vacuum hoses and the intake plate on top of upper. It should take a t20 torqs screwdriver unless the screws have been changed. Then remove the bolts. There are 6 or 8 I believe. 2 are hidden under the intake plate. Also make sure you move the electrical "salt and pepper" shaker connections from the back of the upper so you don't have electrical issues on reassembly because those connections control just about everything. I am sure If I missed something someone will chime in.
SleepingStang is offline   Reply With Quote
Old 06-21-2011, 12:59 PM   #3
nickcap's Avatar
Thanks
Old 06-21-2011, 01:01 PM   #4
Re: Paint??
you will probably want to use high temp paint not just any normal paint
Old 06-21-2011, 01:11 PM   #5
nickcap's Avatar
Re: Paint??
so are the bolts around the manifold or?
Old 06-21-2011, 01:12 PM   #6
nickcap's Avatar
Re: Paint??
ad yea i know thanks spec!
Old 06-21-2011, 03:07 PM   #7
If you are just doing upper and not removing lower then all the bolts you need to remove are the ones you can see attaching upper manifold to lower manifold. No need to remove lower manifold bolts if you are not doing anything with it.
Old 06-21-2011, 09:48 PM   #8
nickcap's Avatar
O ok thanks idk if u should attempt this I don't want to screw anything up
new paint!! 1980rustang 1979-1995 Mustang GT 7 01-26-2010 11:10 AM
I NEED new paint:/ mrjones3133 Mustang Audio & Video 12 08-13-2009 08:06 AM
How much for paint soon2bfastr232 Mustang Audio & Video 10 01-19-2005 11:37 PM
paint V6STANG007 Mustang Audio & Video 35 08-28-2004 01:01 PM
Paint jimmy_beaner Mustang Audio & Video 1 06-22-2004 01:44 PM
05:40 PM
