lowering kits? - Mustang Evolution
Old 06-22-2011, 11:54 AM   #1
08v6's Avatar
lowering kits?
What's the best way to lower a fox car? I don't want to slam it, just drop it a lil and I want it to be a comfortable ride as well
Faster Than A Speeding Ticket! Black 88 Five0, Pull Me Over Red 08v6
08v6 is offline   Reply With Quote
Old 06-22-2011, 06:28 PM   #2
Re: lowering kits?
Well you can low buck lower it by heating the top spring coils with a torch.
BUT it may have negative effects on ride quality and it is difficult to get them all the same.
Your best bet is to use new lowering springs.
American Muscle has these available and you may get a price break from being a member here.
Old 06-23-2011, 07:17 AM   #3
Re: lowering kits?
never heat up springs to lower them ever, Cut them or replace them. I would recommend getting new springs, ford C springs work and can be cut to get the drop you want.
Old 06-23-2011, 04:28 PM   #4
Re: lowering kits?
You know, I have heard this many times over the years, but no one has ever been able to explain why not.
Can you?
I have seen it done quite a few times and the worst thing that ever happened was the ride got a bit rougher when doing that to a variable or progressive rate spring. With the constant or linear rate springs there wasn't any difference other than the reduced travel.
Old 06-23-2011, 08:20 PM   #5
93slowstang's Avatar
Can you?
Well other than the obvious problem with getting them even you are messing with the temperament of the coil. After it cools down it is still significantly softer than the rest of the spring and will be more prone to breaking at that point.
Old 06-23-2011, 08:28 PM   #6
Re: lowering kits?
Yep, I've heard that too.
Getting them even is a problem.
Yes, I know you are taking the temper/hardness out of the spring.
That is how you get it to lower your ride height.
I've never seen or even heard or read about one breaking from doing that though.
I have however seen a spring that had never been tampered with break.
Old 06-23-2011, 08:30 PM   #7
My friend had one snap on his 99 that had been heated, he only had the car for a couple of months and luckily only blew the back tire.
Old 06-23-2011, 08:35 PM   #8
Re: lowering kits?
That's the first one I have heard of.
Years ago before there were lowering kits or special springs, thousands of rodders did it all the time and you never heard of one failing.
Old 06-23-2011, 08:39 PM   #9
Yeah that's how my uncle had his gto lowered back in the day. I believe it's more about how the springs are made and the alloys used today compared to 20 years ago.
Old 06-23-2011, 08:57 PM   #10
Re: lowering kits?
You may have a point there.
I suppose there are differences in the alloys used and the hardening process.
Still, I wouldn't be afraid to try it on a stock set of springs.
Old 06-23-2011, 09:07 PM   #11
I think it would do, especially as a trial to see how far you wanna drop it. I dropped mine 2in.
Old 06-23-2011, 09:08 PM   #12
Using drop springs
Old 06-23-2011, 09:53 PM   #13
Re: lowering kits?
Using drop springs
From how far up did you have to "drop" them to get 2"?
Old 06-23-2011, 09:57 PM   #14
Went from stock height. I did buy the 2" drop springs a few weeks after I "dropped it".
Old 06-23-2011, 10:44 PM   #15
Re: lowering kits?
Nice "stance", any trouble with anything rubbing or hitting the ground over bumps?
Old 06-23-2011, 11:08 PM   #16
If I hit a bump while turning the front tires will rub a little. I left some of the negative camber because of the 225/45 in the front, but I love how the tires are tucked under the fender wells. I also run a 275/45 in the back with no rubbing issues at all.
Old 06-23-2011, 11:30 PM   #17
Re: lowering kits?
I am considering changing my 86 from a street/strip suspension to more of a road race suspension and lowering will be part of the change.
That info will help me decide how much to lower and tire sizes I can use.
Old 06-24-2011, 05:11 AM   #18
I love how it looks and the handling is night and day but I do feel every bump in the road. Also I have 17" wheels.
Old 06-24-2011, 09:29 PM   #19
Re: lowering kits?
Hmmm, That's something I will have to consider.
When I was younger it wouldn't have bothered me, but now after two spine injuries I have to be a bit more careful.
Thanks for the input.
Old 06-24-2011, 10:45 PM   #20
mustangbill00's Avatar
Stick with a progressive rate spring and a good shock that can be adjusted to a soft setting. Mine rides pretty decent with the Eibac's and adjustable shocks BUT, the soft setting let's the suspension travel farther and makes it more prone to hitting the K-member brace on high spots in the road.
mustangbill00 is offline   Reply With Quote
Old 06-25-2011, 01:34 AM   #21
NP, I have back problems after a head on collision and it's not too bad of a ride, but I have to slow down a lot for the bigger bumps. Had to sacrifice ride quality for the look and handling I wanted. I believe a 1.5 drop would be more than sufficient while still maintaining some ride quality.
Old 06-29-2011, 05:15 PM   #22
Re: lowering kits?
Deal on some lowering springs - LRS
Old 06-29-2011, 10:49 PM   #23
That's a damn good deal.
Old 06-30-2011, 07:56 AM   #24
Titus Wadicus
svtlx's Avatar
Re: lowering kits?
that is an awsome deal.... i paid $79 shipped for my 2" drop springs from ebay.
the "suspension starter kit" is a real good deal too. i paid close to that for my rear control arms alone....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 06-30-2011, 10:34 AM   #25
wc3john's Avatar
Re: lowering kits?
I wish I could find a good deal on shocks and struts for my gt, eibachs are staggering $450!
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-30-2011, 10:03 PM   #26
Titus Wadicus
svtlx's Avatar
Re: lowering kits?
i found a decent deal on sum kyb's off of ebay...
Old 06-30-2011, 10:33 PM   #27
03GT88's Avatar
Let me know how those ebay springs work out.
03GT88 is offline   Reply With Quote
Old 07-01-2011, 12:17 AM   #28
wc3john's Avatar
Re: lowering kits?
how much did you get them for?
Old 07-01-2011, 08:56 AM   #29
Titus Wadicus
svtlx's Avatar
Re: lowering kits?
they're installed, but the car is still on stands at the moment. i got them cause another member in here recommended them... he's got them on his '01 and loves them.
Old 07-01-2011, 08:59 AM   #30
Titus Wadicus
svtlx's Avatar
Re: lowering kits?
i cant remember, but i know it was under 300. they offered an lx kit, and a quad shock kit for gt's
« top | speakers »
Suggested lowering kits poloka 2011-2014 Mustang GT 11 05-20-2011 09:54 AM
Lowering my 04 GT Talon 1996-2004 Mustang GT 13 07-15-2009 08:02 PM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
10:05 AM
