Changing an ignition 1995 - Mustang Evolution
Old 06-24-2011, 11:21 AM   #1
Nate98stang's Avatar
My 95 gt ignition broke last night in the on position I can take the key out and it's as if it's still in the on position radio plays brake light and battery light stay on, I can also start my car but can not shut it off how do I change the ignition?
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 06-24-2011, 06:11 PM   #2
mustangbill00's Avatar
Under the ignition there is a small hole. With a small punch ( I used an Allen wrench) insert it into the hole and pull the ignition out. There is a pin inside that hole that releases the ignition, also I think the key needs to be in a certain position. I'm sure someone will chime in with more details, but it's pretty easy.
mustangbill00 is offline   Reply With Quote
Old 06-24-2011, 09:10 PM   #3
Thanks so I don't have to pull my wheel off or anything a friend said he thought the wheel had to b pulled
Old 06-24-2011, 09:29 PM   #4
YW. I think to pull the outer section out, you need to pull the steering wheel and is a little more involved, but the inner ( the guts ) just slides right out by pushing in the release button. Somewhere in here it tells you how to do it in more detail but I can't remember where.
Old 06-24-2011, 09:50 PM   #5
This might also help.
http://en.allexperts.com/q/Ford-Repa...g-Ignition.htm
Old 06-24-2011, 10:23 PM   #6
So is that the whole ignition? Or just the part that locks the key in the ignition ?
Old 06-24-2011, 10:39 PM   #7
Ok so here is what u need to do I almost had to do it to mine! lol so I been looking it up the passed week to see how to do it haha but to see that pin he is talkin about, go ahead and go to ur part store and buy an ignition cylinder with keys. Should be about $15 then when u get it u will see the pen he is talkin about but anyways it will come with instructions itself! Easy fix. Hope this helps!
93stang306 is offline   Reply With Quote
Old 06-24-2011, 10:41 PM   #8
Originally Posted by 93stang306
Ok so here is what u need to divi almost had to do it to mine lol so I been looking it up the passed week haha but to see that pin he is talkin about, go ahead and go to ur part store and buy an ignition cylinder with keys. Should be about $15 then when u get it u will see the pen he is talkin about but anyways it will come with instructions itself! Easy fix. Hope this helps!
Thanks really appreciate it everyone has been very helpful
Old 06-24-2011, 10:47 PM   #9
Np like I said when I got my ignition cylinder it had instructions in it! Also don't turn the key befor u put it in. I Hurd it will lock it and u will be screwed haha so just leave key in it and leave it alone. Just install it as directions say. And one more thing look at ur ignition see if it is black or chrome. (the front where u put ur key and turn) they will ask u when u go to the part store. Or should ask u.
Old 06-24-2011, 10:48 PM   #10
The link refers to the Ignition Lock Cylinder ( what your key goes into ) and that is attached to the Ignition Switch inside the column. There is a tab that sticks out the end of the lock cylinder that fits into the ignition switch. I'll post some pics of the two.
Old 06-24-2011, 10:52 PM   #11
Mines chrome
Old 06-24-2011, 10:53 PM   #12
Lol! I guess I was a little slow to reply. You shouldn't have any problems, good luck.
Old 06-24-2011, 10:54 PM   #13
K just make sure u tell them that when u get ur new one because the black one and the chrome one look completely differant as far as internal and how big they are. The black one has a piece that extends farther then the chrome one. reason I know is because I had to take the chrome one back for the black one haha
Old 06-24-2011, 10:55 PM   #14
And this was Wed I took it back haha I shoulda kept it a little longer I could have showed u some pics but oh well it seems easy! Go for it!
Old 06-24-2011, 10:58 PM   #15
That's interesting! I learnt something new today LOL. I will keep that in mind when I get my new one. I pulled mine out but have not replaced it yet.
Old 06-24-2011, 11:03 PM   #16
Yea I didn't know it untill I had to take another trip back to town to replace it with the right one, then a few hrs later I found my keys so I took it back again haha
Old 06-24-2011, 11:08 PM   #17
So the new ones come with keys right?
Old 06-24-2011, 11:15 PM   #18
Yea 2 keys
Old 06-24-2011, 11:48 PM   #19
Yea 2 keys
K thanks guys
Old 06-26-2011, 07:23 PM   #20
So that did not fix my problem
Old 06-26-2011, 07:29 PM   #21
It must be the ignition switch itself. I'm not an expert, that's just my personal opinion.
Old 06-26-2011, 10:53 PM   #22
There's a blackwire hanging under the colum if I ground it out to metal it make the door ding
Old 06-26-2011, 11:14 PM   #23
If u take a pic I can look at mine and tell ya where that wire needs to go
Old 06-26-2011, 11:21 PM   #24
Alright I'll try to get a pic on here tomarrow appreciate the help as always guys
01:01 PM
