Remote door locks - Mustang Evolution
Old 06-26-2011, 10:59 AM   #1
jhagan1980's Avatar
Remote door locks
Where is the module for remote door locks suppose to be? I read online that if you jumper the gray connector while the ignition is on, your door locks will cycle and you would be able to reprogram your remote. Mine cycled, so does this mean that if I get a remote and program it I'll have remote locks? Or do I need the module that I'm not seeing
ID:	28383   Click image for larger version
jhagan1980 is offline   Reply With Quote
Old 06-26-2011, 12:08 PM   #2
I don't know about that for sure but I know the 02s if u turn the key back and forth a bit untill the car cycles through locks and unlocks then impress ur button on ur remote and that's how u program them... So when it's cycles try pressing lock then unlock on ur remote
93stang306 is offline   Reply With Quote
Old 06-26-2011, 12:15 PM   #3
jhagan1980's Avatar
Don't have one yet. Trying to make sure it's capable first before I buy a remote.
Old 06-26-2011, 12:17 PM   #4
Re: Remote door locks
I found this in reference to your question, but I can't confirm its accuracy.
1. Turn ignition to RUN or ACC.
2. Momentarily jump pins in programming connector located in LR quarter panel area (Connector will not be plugged
into anything, it will have two pins inside it, if you have to unlug it you have the WRONG one. Not all vehicles
are set up from factory for keyless remotes) All doors will lock then unlock to confirm programming mode.
3. Press any button on first keyless remote. Door locks will cycle to confirm programming.
4. If programming a second keyless remote, press any button on second keyless remote.
5. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Old 06-26-2011, 06:18 PM   #5
junoS197Bl08's Avatar
It should say in your manual how to do it too
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-27-2011, 08:14 PM   #6
nickcap's Avatar
I did this check the module and see what the FCC Id number is and match it when you buy the remote! Good luck!
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 06-28-2011, 07:20 AM   #7
jhagan1980's Avatar
Where in my pics is the module?
Old 06-28-2011, 10:59 AM   #8
nickcap's Avatar
Where it looks like a handle on the front on the back of that black box you'll see a sticker and that should tell you all of your info
Old 06-28-2011, 11:17 AM   #9
jhagan1980's Avatar
Ok thanks
Old 06-28-2011, 12:08 PM   #10
nickcap's Avatar
Yup
06:51 PM
