95 GTS code help and ideas....Please - Mustang Evolution
Old 06-27-2011, 12:05 AM   #1
ok car set while I was deployed. came home and getting bad bog and low miss/rough idle. Code 157 replaced MAF. Code 189 pops up. swapped the two O2 sensors and now my autometer air/fuel meter isnt working. So I am guessing that the (left) drivers side o2 was no bueno. was too late on sunday to get to parts store. I am going to replace both o2 tomorrow, but both were new Bosch only about 2 years old, and only 1 years worth of use. I also replaced plugs, were Double Platinum Autolites, went with Platinum autolites AP26 I sprayed the hell out of the engine bay with starter fluid no Vac leaks to be found. Whiskey Tango Foxtrot! I have reset the DTC codes everytime I made a change, and done the KOEO test a friggin million times, why wasnt the 02 codes showing before I replaced the MAF? did the MAF trash the 02 sensors? Any ideas? Thanks Baffled here. When I left AUG1 last year no problems, wife started and let it idle once a week while I was gone. Could that have crashed the sensors? Thanks again oh great gurus of all things Stang!
Txjason1 is offline   Reply With Quote
Old 06-27-2011, 12:11 AM   #2
Re: 95 GTS code help and ideas....Please
Starting it up and just letting it idle probably didn't get the O2 sensors or catalytic convertors hot enough to do their job properly. You might need to just take it for a long drive to clear it up if possible. I'd also put some fresh fuel in it.
Old 06-27-2011, 12:13 AM   #3
Send a message via Skype™ to Texastboneking
Bad gas in gas tank. Burns funny causing it to run bad and throw fuel to air ratio off. Run premium for a couple fill ups with fuel system cleaner
Texastboneking is offline   Reply With Quote
Old 06-27-2011, 12:49 AM   #4
+1
If you run the premium then switch back to a lower grade, you will have to remember to allow your computer time to relearn. From my experiences with my 86 GT, this can take 20-30 miles of driving under various loads.
Old 06-27-2011, 12:50 AM   #5
Pete07GT's Avatar
Send a message via ICQ to Pete07GT Send a message via AIM to Pete07GT Send a message via Yahoo to Pete07GT
Completely off topic but found it comical. Sticking a bottle of this at the moment.
When you're going to war, you better have three things if you expect to win: 1. Willpower (One's need to put the petal to the metal); 2. Staying Power (300+ BHP); and 3. Firepower (The wheels of your mustang exploding on the highway like a slug from a .45).
Pete07GT is offline   Reply With Quote
Old 06-27-2011, 12:51 AM   #6
Every thing you comment on is off topic....
Old 06-27-2011, 12:53 AM   #7
Pete07GT's Avatar
Drinking, not sticking.
Old 06-27-2011, 10:07 AM   #8
Only had 1/8 tank of fuel in it already filled with premium and a bottle of Lucas. Had stability in it while I was gone drove the **** out of it and no change like I said the o2 swap made my air fuel gauge quit working so I know 1 o2 is bad at least
Old 06-27-2011, 10:08 AM   #9
Give it a go. Replace em
Old 07-01-2011, 03:57 PM   #10
Stang.racr's Avatar
Any news yet, have u cleaned the iac tube
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
11:20 AM
