Help! clutch loose? - Mustang Evolution
Old 06-28-2011, 05:42 PM   #1
Help! clutch loose?
So, i finaly decided to pull the stang out of the garage today and drive it around a little... well after getting it out of the garage and down to the end of the drive way i realized... my clutch has a TON of play in it... it catches at the very bottom... and barely it seems like. Now i can put my foot under the petal and pull up on it and it comes up about 2 inches or more! Help! whast do i do and how do i tighten it? i looked behind the fire wall and all i see is the huge break booster box.. Do i adjust it from inside the car? if anyone can take some snap shots of what i can adjust that would be great.. hope my clutch isnt messed up!
93stang306 is offline   Reply With Quote
Old 06-28-2011, 05:53 PM   #2
Re: Help! clutch loose?
U need to adjust the quadrant under the dash u can't miss it it is a white thing with teeth on it all I have right now is automatic so I can't post any pics
1995 stang is offline   Reply With Quote
Old 06-28-2011, 08:59 PM   #3
What white thing with teeth? I don't see it?
Old 06-28-2011, 09:06 PM   #4
Pull the clutch pedal up with your foot or hand.
When you pull up on the clutch, listen for a click.
You may have to push the clutch pedal in a bit to remove slack from the clutch cable after adjusting, before adjusting again.
If you hear no clicks and get no results then your quadrant may need to be replaced or your cable may be stretched out.
I would recommend an aftermarket quadrant with a firewall adjuster as a replacement.
Old 06-28-2011, 09:23 PM   #5
Can u link me to a site to by one? A good one.
Old 06-28-2011, 09:56 PM   #6
American Muscle
Latemodel Resto
Old 06-29-2011, 03:34 AM   #7
It's above the pedals
Old 06-29-2011, 07:12 AM   #8
if its stock you can manually adjusted it, this may or may not last~ depends but give it a try.
Not sure on older ones but the 94+ you can push in the clutch petal with your left hand reach up and grab the quadrant with your right (above gas petal i believe) then ease out the clutch and hold the quadrant a bit to keep tension on it, it will click as the clutch petal gets close to being out do a few times, but not to much
Old 06-29-2011, 09:52 AM   #9
Right older ones r like that also
Old 06-29-2011, 01:30 PM   #10
did this happen at once or did it gradually get that loose? you may have stretched the cable.i could be wrong but if the quadrant is stock you probably can't adjust it un.der the dash.you can if it has a triple quadrant though.i think you might be able to adjust it at the trans.on the driver side of the trans there is a cover .take that off and check see if you have an adjustable cable or not .might be able to tighten it up.while you got the cover off see of the fork it is attached to looks bent.
Old 06-29-2011, 03:28 PM   #11
Unfortunately I think it's stock. I guess it happened all at once, I noticed in when i got down to the bottom of my 100 ft driveway lol pretty much rolled down my driveway then put it in first and that's when I notices it, I tries to look under the dash but didn't really see much
Old 06-29-2011, 03:36 PM   #12
its way under there probably as high as your heater controls except attached to your clutch pedal
Old 06-29-2011, 03:54 PM   #13
It would be better to buy a aftermarket quadrant
Old 06-29-2011, 08:24 PM   #14
mustangbill00's Avatar
I have the steeda triple quadrant, firewall adjuster and adjustable cable and it works great. For around $100 it's worth having all that adjustment. Get rid of that old factory junk.
mustangbill00 is offline   Reply With Quote
Old 06-29-2011, 08:49 PM   #15
i got the same kit.so easy to make adjustments.cant go wrong there.
« aod | top »
03 cobra clutch issues. zinc03 SVT Mustang 4 06-24-2011 12:18 PM
06:10 PM
