94 mustang gt is running hot!!! - Mustang Evolution
Old 06-29-2011, 03:50 AM   #1
My gt started running hot so I put a new thermostat but its still boiling when I turn the engine off.. can anyone give me some clues why??? Please help me..
94 GT is offline   Reply With Quote
Old 06-29-2011, 06:02 AM   #2
Re: 94 mustang gt is running hot!!!
Check your timing amd make sure it isn't retarded.
You may have a blown head gasket.
Your cooling system may be plugged up and needs to be flushed out.
Check your radiator cooling fins and make sure they are not plugged from bugs or other road debris.
Old 06-29-2011, 06:16 AM   #3
How could I check for a blown head gasket????
Old 06-29-2011, 08:42 AM   #4
wc3john's Avatar
my GUESS would be a compression test, a blown head gasket I THINK will lose some compression.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-29-2011, 08:45 AM   #5
The quick test is to look at your coolant to see if there is oil in there...and your oil to see if it looks like it has water in it (it will be a lighter color, pushing brownish depending on the amount of water present).
That won't guarantee you don't have a blown gasket, but if you find oil or water where they aren't supposed to be, it will about guarantee you have a blown gasket.
Old 06-29-2011, 09:56 AM   #6
U may need a new radiator cap I've had the same problem a while back
1995 stang is offline   Reply With Quote
Old 06-29-2011, 11:00 AM   #7
Greg687's Avatar
Region: New Mexico
also make sure your cooling fan is kicking on. If the car is hot and it's not, then it could be the fan switch, the fan relay, or the fan itself. Try turning on the A/C because that is normally wired to turn on the fan. If that doesn't work it's either the relay or the fan.
Greg687 is offline   Reply With Quote
Old 06-29-2011, 12:03 PM   #8
When I turn my A/C on it gets worse and idles about .2000 rpms
Old 06-29-2011, 06:09 PM   #9
If so then u will Probally need a new fan
Old 06-29-2011, 06:11 PM   #10
I just replaced the fan on my 95 gt cause it started running hot I would say it is the fan
Old 06-30-2011, 12:38 PM   #11
Ok... I've tried everything I'm about to flush the system... if this doesn't work I guess I have a blown head gasket...
Old 06-30-2011, 01:03 PM   #12
Greg687's Avatar
Region: New Mexico
Don't guess. Problem solve. Did your fan ever come on when it was over heating? Was it boiling over, or are you just getting numbers off of the gauge? What EXACTLY have you done to it to figure out the problem.
Old 06-30-2011, 01:15 PM   #13
The fan comes on, I burp the system, new stat, now I'm flushing the system.. what else can I try I love my stang and don't wanna see it like this....
Old 06-30-2011, 01:32 PM   #14
If you have water in your exhaust u have a blown head gasket
16218 is offline   Reply With Quote
Old 06-30-2011, 03:28 PM   #15
Greg687's Avatar
Region: New Mexico
Water in the oil. Oil on the coolant. Antifreeze smell out of the exhaust would all indicate a blown head gasket. What didyou see when you flushed it? So the fan comes on. That's good. Another thing to check is coolant flow. Make sure the water pump is flowing (had one go bad the impeller broke) and that thermostat is opening.
Old 06-30-2011, 03:38 PM   #16
Send a message via Skype™ to Texastboneking
Listen to this guy. He knows what he is talking about
Texastboneking is offline   Reply With Quote
Old 06-30-2011, 09:14 PM   #17
Greg687's Avatar
Region: New Mexico
Thanks.. broken cars I have experience with
the hot rodding stuff I am learning.
Old 07-01-2011, 02:25 AM   #18
Well I've been tinkering all nite and finally I've found a solution to my over heating until I can put it in the shop... I unplugged the temp sensor and the cooling fan came on... I'm changing the sensor when I wake up... will this cause any problems by leaving it unhooked???
Old 07-01-2011, 10:03 AM   #19
Might run a little rich or lean.
Old 07-01-2011, 10:29 AM   #20
Greg687's Avatar
Region: New Mexico
Seems we covered this already...
Old 07-01-2011, 02:45 PM   #21
Stang.racr's Avatar
How is water pump, u should have a tail tale hole on wp that will leak water to let u know if it goes out, also when head gaskets go out, most of the time u can pop the radiator cAp and see parts of the head gasket floating in your water, when u do get it fixed, u can throw in a bottle of water wetter. It cooled mine in between 5-10 degrees at normal operating tempature
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
CPO Mustang 2010 GT Premium ??? wickerman 2011-2014 Mustang GT 14 07-11-2011 10:57 PM
2006 GT Stock Bullit 17x8 -> 2002 Mustang v6 FghtinIrshNvrDi Mustang Wheels & Tires 6 06-27-2011 09:29 AM
1990 mustang GT mustangcobra90 1979-1995 Mustang GT 12 06-25-2011 10:29 PM
05:47 PM
