Trade for cobra??? - Mustang Evolution
Old 07-01-2011, 01:34 AM   #1
Trade for cobra???
So I was wondering if I should trade my car for a cobra....
Here is his mod list...
Red 93 cobra
Motor ......351 block with a 408 stroker kit 60 over has edelbrock Vic jr. Heads 30lb inj. Edelbrock water pump bbl long tubes stainless pro. Products fu
el rails and remote mount reg. Trick flow r series upper and lower egr elem. 75mm throttle bod pro m mass air meter 88 mm be cool 4 core alum rad. Black
magic fan. Custom grind bullet roller cam huge jewel 1.7 rail rockers mad billet dist. Svo rpm extender ati sfi balancer underdrives arp bolts fidanzia a
lum fly wheel centerforce clutch Tremec 3550 trans with steeda short throw alum drive.shaft 410 gears powertraxx rear diff 31 spline moser axles c clip e
lems. Diff girdle upr upper lowers tubular k member and control arms coil overs on front eibach pro launch on rear. With 5 way shocks fronts are 10 way
upr caster camber plates mac prochamber pipe with flows piped out rear +more
And mine
My car has 75k miles. It has a 306 stroker in it with alot of mods. No rust. Very clean garage kept and never driven in the rain. I'll try my best to get everything listed, but I'm sure I'll be forgetting a few things
Holley heads
Msd ignition al2
Msd blaster
Msd distributor
Trickflow upper intake throttle body
Under drive pullies
3.73 gears
T5 world class trans
Hurst short throw shifter
Tack with shift light
Temp and oil pressure gauge in place of air vents
A/c deleted
X cam
24lb injectors
K&n air intake
Bbk X pipe
Flow masters, turn downs befor back axle
Bbk long tube headers
Bbk fuel pressure regulator
Fuel pressure gauge
Smoked tail lights
Battery relocated in back right
Aluminum drive shaft
Spec stage 2 clutch good for 600 hp
Mickey thompson drag radials practically brand new.
On weld racing wheels
Maximum motorsports tubular k
And here is a few pics of both
ID:	28522   Click image for larger version
ID:	28524   Click image for larger version
93stang306 is offline   Reply With Quote
Old 07-01-2011, 01:41 AM   #2
Send a message via Skype™ to Texastboneking
Re: Trade for cobra???
now is it definably a true cobra?
and also im not to familiar with the old 5.0 cobra and mustangs.. what were the differences?
Texastboneking is offline   Reply With Quote
Old 07-01-2011, 04:00 AM   #3
Pete07GT's Avatar
Send a message via ICQ to Pete07GT Send a message via AIM to Pete07GT Send a message via Yahoo to Pete07GT
How can you be a Ford mechanic and not know about fox body mustangs?
When you're going to war, you better have three things if you expect to win: 1. Willpower (One's need to put the petal to the metal); 2. Staying Power (300+ BHP); and 3. Firepower (The wheels of your mustang exploding on the highway like a slug from a .45).
Pete07GT is offline   Reply With Quote
Old 07-01-2011, 07:08 AM   #4
Not to be an *** but, that was just a waste of a reply, why would you even reply to this thread if ur just going to bash someone? Lol you could atleast give me your opinion on the topic. And yes I believe it is a real cobra, but not sure about the differences in them those years
Old 07-01-2011, 07:14 AM   #5
a TRUE 93 cobra is going up in value, if its clean and near stock which that one doesnt sound to be...
Old 07-01-2011, 07:28 AM   #6
Pete07GT's Avatar
Oh no, feel free to be an ***. Matter of fact, use that term copiously when referring to TexasBoneKing and I. You will find it fits us well.
Old 07-01-2011, 10:22 AM   #7
Because most of the fox bodies are older than I am...
Old 07-01-2011, 10:23 AM   #8
Haha that's just petes thing. He gets a kick out of it. Just ignore the ***
Old 07-01-2011, 10:24 AM   #9
So what were the differences in a 93 cobra and gt?
Old 07-01-2011, 01:02 PM   #10
Stang.racr's Avatar
Gt40 heads And cobra intake for one, a slight body package and wing, 17 inch cobra rims
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-01-2011, 01:03 PM   #11
So nothing to the lower end then?
Old 07-01-2011, 01:45 PM   #12
So should I make a trade on this cobra, or is there somethin I'm missin about my car that makes it more valuable then the cobra?
Old 07-01-2011, 02:31 PM   #13
Stang.racr's Avatar
Same bottem end, 93 cobra r is a different subject. It looks like a fair trade. I would say with that cobra u would have alot more torque. 93 cobra are pretty rare these days, that one is modded as hell though, I would probably trade em
Old 07-01-2011, 04:08 PM   #14
Loc: Austin,TX
I would trade also but all jokes aside.....when buying or trading for what someone says is a Cobra....do your research so you arent disappointed later when you find out its a clone. Just be safe is all im saying,if it is the real deal....go for it!!
Old 07-01-2011, 04:59 PM   #15
sonic04edge's Avatar
Send a message via AIM to sonic04edge
That's like saying you know nothing about the original mustang....You know the internet has lots of useful information! lol.
If its a real cobra I would, but at the same time your car is super clean! Doesn't sound like you would be really losing anything doing it and there is just marginal gain by doing the trade. Hard to say.
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 07-01-2011, 05:40 PM   #16
Loc: Austin,TX
Txboneking aka certified lube tech?
Old 07-01-2011, 06:01 PM   #17
bigcolt45's Avatar
Just to put my two cents in ford is not teaching bone king ancient technology.... Must fox bodies are worked on by the owner now days .... I have worked on cars for a long time and don't think I have worked on but a handful of fox gt or cobras .... Ford is busy with there variable valve timing and turbo boost systems.... And to the original poster a gt can be a cobra clone for about 1000 bucks where I live.... So be careful and a highly modified cobra in actual value would be worth less than an all original..... I love my 89 gt and if I put 15 grand into it I would probably never recoup the money.... So u buy it as a fast as hell mustang and not for potential cobra value..... Plus check the vin online
bigcolt45 is offline   Reply With Quote
Old 07-01-2011, 09:09 PM   #18
I found this info on the SVT Performance website.
Absolutely no 93 Cobra convertables made.
There were 4993 Cobras and 107 Cobra R's produced in 1993 for a total of 5100.
1FACP42D... is how the VIN should read. No Cobra came with cruise control. Only 5 options were available - PWR drivers seat, leather, CD, Rear window defrost, and Sunroof. Engine block heater, CA emissions, High Altitude principle use, and million mile odometer were also available, but don't show up on the door tag, buck tag, or VIN.
• Unique 17x7.5 turbine style wheels (unique offset - 93 Cobra is 3/4" wider per side with unique front rotors with taller hats)
• Opened up grill area with running horse insert
• Unique rear bumper, side skirts and grill opening
• Rear disc brakes
• Snake emblems on fenders should be non-directional (DS faces to the back, passenger side faces to the front, unique to 93 Cobras)
• LX style tailpipes
• SVO style tail lights
• Unique rear spoiler
• GT40 Iron heads (3 "bars" should be visible on front of head, "GT" cast into head under valve cover
• Black stamped steel valve covers (94-95 Cobra valve covers have "Cobra" embossed into them).
• Crane 1.7 roller rockers, cast aluminum
• Available in 3 colors only: Teal metallic, Vibrant Red (kinda orange red), Black
• 70mm MAF
• 65mm throttle body
• Cobra (cast GT40) upper and lower intake
• Unique mufflers and tailpipes (extended hangers on LX style tailpipes)
• Smaller front sway bar - 28.5mm as compared to the larger 33mm unit used on the GT, the rear bar measured 21mm
• 4 cylinder rear springs and regular 5.0 front springs. The front springs were 425/530 lbs./in progressive rate, while the rear springs had a linear rating of 160 lb./in versus a progressive 200/300 lb./in. rate used on the GT.
• Unique struts and shocks (Tokico was the OEM supplier)
• Unique cam (Used in 93 t birds and cougars, 94-95 Australian falcons)
• Unique EEC (X3Z catch code)
• 24# injectors
• 1" bore master cylinder
• Larger brake booster
• Unique tranny (World Class T5) - phosphate coated 2nd and 3rd gears, steel pocket bearing retainer
• Stock 5.0 fuel pump
• Hardened driveshaft yoke
• Unique brake proportioning valve
• Non cruise leather wrapped steering wheel
• Lettered floormats
• Unique crank and water pump pulleys (underdriven crank, overdriven WP)
• 3:08 ring and pinion
• Higher-rate bushings at the forward end of the rear upper control arms
Exterior Colors: Teal Clearcoat, Vibrant Red Clearcoat, Black Clearcoat
Interior Colors: Black Cloth, Grey Cloth, Grey Leather
The biggest and easiest indicator is the VIN number.
Old 07-01-2011, 09:40 PM   #19
Wow really lol. Ok guess I deserved that for something?
I was saying I don't know the differences from the gts and the cobras from the fox bodies. Mainly because there are like 2 fox bodies left in my town... And ones a sixer...
Old 07-01-2011, 09:44 PM   #20
Thank you!
Old 07-01-2011, 09:44 PM   #21
Very good info. I will be sure to thank you when I get on the computer
Old 07-01-2011, 09:48 PM   #22
I appreciate that.
Old 07-01-2011, 10:02 PM   #23
Loc: Austin,TX
No,I was just messing with ya. All in fun brother.
Old 07-01-2011, 10:03 PM   #24
Lol ok. You usually ain't the joking type
Old 07-01-2011, 10:06 PM   #25
Loc: Austin,TX
SVTperformance.com is a great site even if you just get on there to read. Also check out Cobra bobs webpage,it has everything you want or need to know about the Termis.
Old 07-01-2011, 10:10 PM   #26
Loc: Austin,TX
Well,we gotta maintain that "staff" mentality sometimes so we don't get caught up doing the things that we moderate. If you knew me on a personal level you would know that I'm always about the jokes and acting a fool.
Old 07-01-2011, 10:13 PM   #27
Lol maybe I'll see you tx round up time
06:04 AM
