Idle problem - Mustang Evolution
Old 07-04-2011, 06:37 PM   #1
Stang.racr's Avatar
Idle problem
91 stang, has fuel pressure Gage at schratter valve. Runs perfect while driving. When at idle it will spit and sputter, fuel pressure will drop to zero and jump back up to 40. It will do this over and over till it finally dies. I've never seen a fuel pump or other parts do this, as I said earlier. It runs perfect except at idle, any suggestions. My guess would be to change fuel pump and or regulator, but very odd
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-04-2011, 07:22 PM   #2
Send a message via Skype™ to Texastboneking
Odd indeed... Is it Possible the volts drop at idle and the relay starts kicking on and off??? Weird problem.
Texastboneking is offline   Reply With Quote
Old 07-05-2011, 12:57 AM   #3
vinnygt's Avatar
Re: Idle problem
my friends car had a similar problem and the mechanic said it was a sensor..not sure of the name or anything but just a guess
vinnygt is offline   Reply With Quote
Old 07-05-2011, 10:57 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Idle problem
i dought it's the filter, but crazier shyte has happend. i would try to run a hot wire straight to the pump, drive it and see wut happens. there should be a thick/heavy gauge "pink w/black stripe" wire in the passenger side kick panel in a square grey plug if i recall correctly. if it does the same thing after straight wiring it... u need a new fuel pump.
hope this helps
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-05-2011, 03:37 PM   #5
Stang.racr's Avatar
YeH I'll look at it. I know fp is two years old, I changed fuel filter and hoses at tank two months ago. I'm gonna work on it when I get in from offshore, just a odd situation
Old 07-05-2011, 03:48 PM   #6
wc3john's Avatar
Re: Idle problem
that would be my guess as well, or something electrical.
i know i've seen some crazy crap happen with my fox. good luck!
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-05-2011, 04:33 PM   #7
Stang.racr's Avatar
I need it lmao
Old 07-05-2011, 06:08 PM   #8
Re: Idle problem
Sounds like you may have a pinhole in the pressure regulator diaphragm and it is over fueling at idle.
If it is one that you can take apart, you can see if there is any fuel on the top side of the diaphragm.
Could also be the TPS is acting up.
You might want to test it and make sure it isn't out of range.
May want to check the IAC too.
Old 07-05-2011, 06:19 PM   #9
Pinhole in diaphram. That sounds very plausible.
I got a problem kickerofdoom Mustang Audio & Video 2 07-02-2011 11:39 AM
audio system problem DTRJ04 Mustang Audio & Video 2 07-01-2011 02:09 PM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
06:03 PM
