Powersteering pump - Mustang Evolution
Old 07-06-2011, 07:15 PM   #1
jhagan1980's Avatar
Powersteering pump
I've been having a squeal from under the hood like a bearing is bad. It started off hardly ever doing it and now it squeals 60% of the time. I took the belt off and spun all pulleys, they all spun freely except the powersteering pump. My question is should it have tension on it or spin freely?
jhagan1980 is offline   Reply With Quote
Old 07-06-2011, 07:25 PM   #2
Re: Powersteering pump
It is a pump and will have some drag when spinning it.
If you have a squeal I would suspect that your belt(s) may be worn or loose.
If you have a whine, then it is likely the power steering pump is failing.
Old 07-06-2011, 07:31 PM   #3
jhagan1980's Avatar
The belt is new and believe me I know what a bad bearing sounds like from a previous situation. Every time I pull somewhere so I can pop the hood to try and hear the general area it's coming from, it is stopped already.
Old 07-06-2011, 08:37 PM   #4
I have had new belts squeal too.
Turned ot that my alternator pulley was worn out.
Maybe try putting a bit of belt dressing on the belt to see if the noise goes away?
Old 07-06-2011, 08:57 PM   #5
jhagan1980's Avatar
It's not a belt squeal, it's a bearing. Not sure which one yet other than the power steering pump turning with resistance. New pump is $40 just didn't want to replace it and it not be that.
Old 07-06-2011, 09:05 PM   #6
Water pump, alternator or smog pump bearing?
Can you take a long screwdriver and carefully use it to "listen" to the pump?
Sometimes that can help you pinpoint the problem.
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
06:31 AM
