Camshaft help! - Mustang Evolution
Old 07-06-2011, 11:11 PM   #1
wc3john's Avatar
Camshaft help!
Ive got a stock long block 5.0, (stock upper and lower intake as well) and I have an e cam. The motor is a 91 with 51500 on the clock, NOT 151500. I was wondering if I could just slide the cam in without having to change anything in the heads such as lifters, pushrods and springs. If I DO, please provide what exactly the part is and also a reputable place to purchase from.
Thank you
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-07-2011, 09:33 AM   #2
Normally you would use new lifters since the old ones could cause premature wear of a new cam!!! As far as pushrods and springs it depends on the cam specs but if it was me I would buy new hardened pushrods and spring to match the cam!!!
SlyFox512 is offline   Reply With Quote
Old 07-07-2011, 02:10 PM   #3
wc3john's Avatar
Re: Camshaft help!
so basically all new valve train parts except for the roller rockers?
Old 07-07-2011, 02:53 PM   #4
I believe your roller rockers should be fine, but just remember to check piston to valve clearance!
Old 07-07-2011, 07:06 PM   #5
Re: Camshaft help!
Thank you
You should change the lifters and valve springs at the minimum.
You can visually check the pushrods for damage and roll them on a flat surface to see if they are bent.
You can get your parts at American Muscle or LRS
They are site sponsors and will likely give you the best deal.
Here is a link to a PDF file of - Ford Cam Specs
Old 07-07-2011, 10:11 PM   #6
Send a message via Skype™ to Texastboneking
Again Trojan you never fail to give out great information
Texastboneking is offline   Reply With Quote
Old 07-07-2011, 10:24 PM   #7
Re: Camshaft help!
Thank you for saying so.
I try my best to ensure the information I post is accurate and applicable.
You do a great job yourself.
Old 07-08-2011, 10:08 AM   #8
90blue5.0gt's Avatar
And after could you let me know how the cam does I have the same cam also but I finishing up my motor now can't wait till it's finished
90blue5.0gt is offline   Reply With Quote
Old 07-08-2011, 11:18 AM   #9
wc3john's Avatar
Re: Camshaft help!
except AM doesnt sell springs... i'll probably get them from LRS. so at minimum, lifters and springs... will new factory springs work? The E cam is only .054 bigger lift @ the valve than stock.
Old 07-08-2011, 12:07 PM   #10
Re: Camshaft help!
They should work fine.
Is the price difference high enough to make you want to use stock springs?
Most people do not think about valve springs as having much effect on how their vehicle performs, but they do have a significant impact.
A use weakened, fatigued set of valve springs or a set that has inadequate seat pressure will not keep the valves sealed up properly leading to leaking valves that allow combustion gasses to escape to early causing a drop in cylinder pressure and reduced performance and economy.
Old 07-08-2011, 12:48 PM   #11
wc3john's Avatar
Re: Camshaft help!
how is this?
1979-95 Mustang 5.0L/5.8L Trick Flow Valve Spring Upgrade Kit for Oe Style Cast Iron Heads at LRS - Same Day Shipping!
and this?
1985-95 Mustang 5.0/5.8L Oem Hydraulic Roller Lifters, M-6500-R302 at LRS - Same Day Shipping!
its within my budget and thats the minumum you were saying
Old 07-08-2011, 03:41 PM   #12
Re: Camshaft help!
Yes, those will do the job.
Be sure to tell them you are a member here.
It might get you a discount.
03:02 PM
