Fuel filter - Mustang Evolution
Old 07-07-2011, 02:22 PM   #1
A.K.A. Baby-D!
Fuel filter
Where can I find the fuel filter on my 88 GT
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 07-07-2011, 02:59 PM   #2
Stang.racr's Avatar
Just forward of your gas tank under your car
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-07-2011, 03:00 PM   #3
90blue5.0gt's Avatar
Look under the back of the car and look up behind your tank it's there with the hoses on each end I'm sure your changing it don't worry about the plastic clips the new filter should come with new ones but make sure you put it in right it will tell which way the flow goes it's very easy watch out the lines will pour a little fuel so don't be alarmed
90blue5.0gt is offline   Reply With Quote
Old 07-07-2011, 06:58 PM   #4
SleepingStang's Avatar
Sometimes it's easier to remove also if you relieve the fuel pressure from the system. Not so much gas will exit then also.
SleepingStang is offline   Reply With Quote
Old 07-07-2011, 07:30 PM   #5
Oh very good idea cool got to remember that
Old 07-07-2011, 08:26 PM   #6
Not sure if it's the same on an 88 as it is on my 92, but this is the easiest way. Go in the trunk or wherever the inertia switch (shuts off fuel in event of a crash) and unplug the wiring harness. This stops the fuel pump from pumping. Start the car and let it run till it shuts off. This will be a relatively short time. Then replace your filter or work on your fuel system. I use this method for all my cars and I spill very little fuel and have less risk of getting it in the eyes and mouth.
Old 07-07-2011, 09:26 PM   #7
Very good see it's amazing I never thought of that stuff well you learn something new every day I guess thanks
Old 07-08-2011, 08:20 AM   #8
A.K.A. Baby-D!
Thx everyone for all the info and tips. Found and replaced it. That was long over due....
Current:
Previous:
Old 07-08-2011, 10:11 AM   #9
You welcome your supposed to change it like every oil change I was told I don't know
Old 07-08-2011, 10:13 AM   #10
03GT88's Avatar
No your not suppose to change it every oil change whoever told you that was mistaken. You should change it about every 30,000 miles. Unless your extremely bored change it at the oil change.
03GT88 is offline   Reply With Quote
Old 07-08-2011, 12:10 PM   #11
Send a message via Skype™ to Texastboneking
+1
I went 70,000 miles in my truck without replacing one and it still ran fine. Put a new one in it and still couldn't tell a difference. Just dont go buying cheap gas at cheap stations. They have a higher chance of having dirty gas
Texastboneking is offline   Reply With Quote
Old 07-08-2011, 01:36 PM   #12
jhagan1980's Avatar
Originally Posted by Texastboneking
+1
Or right after a fuel truck makes a delivery, it stirs up the fuel tank.
jhagan1980 is offline   Reply With Quote
Old 07-08-2011, 02:40 PM   #13
03GT88's Avatar
That's true too. I replaced my filter on my gt when it hit 50000. The filter poured out brown colored crap. It was probably the original one.
Old 07-08-2011, 03:21 PM   #14
Yea mine to and it was replaced about 6 months ago and I changed it my car started stalling out and I replaced fuel pump etc and now I think it's fine
BBK Vs. UPR fuel rails natm02 1996-2004 Mustang GT 9 08-07-2011 07:10 PM
bullett fuel door 1996v6stang General Car Discussion 3 07-06-2011 07:13 PM
Fuel injectors 2001 v6 Mustanglife Pre-2005 V6 Mustang 9 07-02-2011 10:36 AM
Fuel tank size Pascullon Pre-2005 V6 Mustang 4 06-28-2011 08:23 PM
01 Mustang V6 having issues Mustanglife Pre-2005 V6 Mustang 29 06-25-2011 10:33 AM
11:03 AM
