Convertible Quarter-Window Help? - Mustang Evolution
Old 07-08-2011, 01:18 PM   #1
nickcap's Avatar
Hey guys,
On my Mustang GT Convertible the back Quarter-Window has a hole were the weather strip was, and there is weather stripping in the car obviously haha! But I attached a picture and this is the biggest one! The passenger side hole is in the same place but smaller then this one on the drivers side! What do I do? Or how do I get it fixed? I don't want to leave it like that to long, the water doesn't go directly into it but I think it is dripping in slightly when it rains! Thanks guys for your future help and I dot know what I would do without this forum!!!
Thanks
NickCap
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 07-08-2011, 02:40 PM   #2
Re: Convertible Quarter-Window Help?
if you raise the top a little bit you can access the weather stripping that SHOULD be there, thats what goes in that little hole. Mine likes to move around a bit on the drivers side and I have to raise the top just a bit, put down the quarter window, and then pull it back down a bit to get it into the right place. Take a pic with the quarter window down and the top up about 20% of the way back so we can see the weather stripping (more to the left than your last pic)
Old 07-08-2011, 04:35 PM   #3
What year is your car?
Be sure to put that into your posts or in your signature, so when you ask questions we can make sure we give you the correct information.
Old 07-09-2011, 10:11 AM   #4
nickcap's Avatar
Ok thanks guys I will when I get home I'll check it out the other one is smaller and it's a 1995 I'll put it into my signature
Old 07-09-2011, 11:52 AM   #5
Is this the weatherstrip piece? CVT Weatherstrip
Old 07-09-2011, 09:52 PM   #6
nickcap's Avatar
OMG I can't believe you found them thanks troj!! if the method that spec has told me doesn't work cause the weather strip is bad I'll def buy them thanks all of you!!!!
Old 07-09-2011, 10:41 PM   #7
You're welcome. Glad I could find what you needed.
Old 07-10-2011, 08:19 PM   #8
nickcap's Avatar
I tried am I doing something wrong it still has a hole In it
Old 07-10-2011, 11:05 PM   #9
nickcap's Avatar
Pics please help
ID:	28736   Click image for larger version
Old 07-10-2011, 11:22 PM   #10
Originally Posted by nickcap View Post
Pics please help
Does anyone in your area have a convertible in your year range that you could look at to compare?
Old 07-11-2011, 06:23 PM   #11
nickcap's Avatar
No unless I go to a car show but still idk exertions I put it up it moves is there a website that will tell me whats with it
Old 07-11-2011, 08:16 PM   #12
If there is I've been unable to find it.
Can you determine what is supposed to hold it in place?
Maybe the adhesive just let go and you need to glue it into place?
Old 07-11-2011, 08:49 PM   #13
nickcap's Avatar
No it clicks in and it should stay in
Old 07-11-2011, 08:53 PM   #14
I need some help with installing lowering springs on a 94 mustang gt
94 GT is offline   Reply With Quote
Old 07-11-2011, 09:52 PM   #15
Go here & start a new thread please.
Old 07-11-2011, 09:55 PM   #16
There has to be something is missing that holds it in place?
Or, if the fastener is built in it has gotten too weak to hold it.
Can you take it out and photograph the back side and ends?
Old 07-12-2011, 10:58 AM   #17
nickcap's Avatar
yes i will but its hard to believe both sides are doing it?
Old 07-13-2011, 08:30 PM   #18
nickcap's Avatar
Still can't fix after moving it around it keeps coming out of place idk it's weird that both sides are doing it
Old 07-13-2011, 11:24 PM   #19
Get some 3M Super Weatherstrip Adhesive and glue them into place.
Old 07-14-2011, 09:34 AM   #20
nickcap's Avatar
Haha good idea I'll try that dude and tell you how it comes out is tHat stuff sticky or should I just rivet it?
Old 07-14-2011, 10:08 AM   #21
It is very sticky. I have used it on numerous vehicle's weatherstripping over the years with no problems. It is very important to follow the instructions to get good adhesion. Below is what I remember, but read the package first too.
I wouldn't use rivets unless you can do so in an area where they will not contact the window glass. If they contact the glass there is a good chance it will chip or shatter at some point.
You will need to clean both surfaces, after they are dry, apply the adhesive to both surfaces and let it "skin" over (let the surface of the glue dry).
Then make sure the parts are lined up perfectly and push them together.
Run your hand/finger up and down the pieces to ensure good contact.
Let them dry for however long the instructions say to and you should be good to go.
Old 07-14-2011, 05:03 PM   #22
nickcap's Avatar
Thanks dude!
Old 07-14-2011, 06:41 PM   #23
Thanks dude!
You're Welcome!
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
HELP 2002 Mustang Window MustangGT02 1996-2004 Mustang GT 7 07-08-2011 11:22 PM
Mustang Window Buttons StreetJMusic Pre-2005 V6 Mustang 1 07-03-2011 07:32 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
03:29 PM
