Injector size? - Mustang Evolution
Old 07-09-2011, 02:40 PM   #1
5.8GT's Avatar
Injector size?
I have an 87 gt with a 5.8 out of a 95 Bronco the injectors are white on the top how do you find out what size they are?
5.8GT is offline   Reply With Quote
Old 07-09-2011, 04:00 PM   #2
SleepingStang's Avatar
Should be 24lbs injectors.
SleepingStang is offline   Reply With Quote
Old 07-09-2011, 04:02 PM   #3
Another point. Assuming those are stock injectors the above info should be correct. If they are aftermarket they could be different. If you are pulling them find a part number on them and search it on the net.
Old 07-09-2011, 04:03 PM   #4
Re: Injector size?
Looks like they are 24 lb injectors.
Name:	Ford Injector Guide.jpg
Old 07-09-2011, 07:05 PM   #5
5.8GT's Avatar
Thanks for the help!
Old 07-09-2011, 07:10 PM   #6
5.8GT's Avatar
Re: Injector size?
Thanks for the info, I am assuming they have not been changed in the past.
Old 07-09-2011, 08:29 PM   #7
mustangbill00's Avatar
Did they make a 19# all black injector?
mustangbill00 is offline   Reply With Quote
Old 07-09-2011, 10:44 PM   #8
Re: Injector size?
Are they Ford injectors?
Part # on them?
Old 07-10-2011, 12:57 AM   #9
5.8GT's Avatar
What size fuel pump should I run? I am still running the factory pump and regulator.
Old 07-10-2011, 07:30 AM   #10
Re: Injector size?
What mods do you have planned?
For basic NA engine mods a 190 lph pump and adjustable regulator should suffice.
If you plan on using a power adder then go with a 255 lph pump and adjustable regulator.
Old 07-10-2011, 05:40 PM   #11
5.8GT's Avatar
Right now the internals are stock I have a Professional Products intake with a 75 mm throttle body, and Mac headers. Down the line I would like to do a 393 stroker.
Old 07-10-2011, 05:44 PM   #12
Part # on them?
D1570ba 1059
They came from autozone.
Old 07-10-2011, 07:50 PM   #13
Re: Injector size?
D1570ba 1059
They are:
DELPHI 20lb/hr High-Z
Part Number Delphi D1570BA (Lucas Old 5207002, Lucas New 621015)
Static Flow Rate @ 43.5PSI (300kPa)
19.86 lb/hr = 208.5cc/min = 150.3g/m
Static Flow Rate @ 58.0PSI (400kPa)
22.93 lb/hr = 240.8cc/min = 173.5g/m
Dynamic Flow Rate @ 43.5PSI (300kPa)
4.44 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Dynamic Flow Rate @ 58.0PSI (400kPa)
5.12 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 16.2 Ohms / High Impedance / High-Z
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference.
The disc rests on a short chimney that surrounds a metering hole.
As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Old 07-10-2011, 07:52 PM   #14
Re: Injector size?
If you are planning on building a good bit of power with the 393, then you may want to go ahead with the 255 lph pump.
Old 07-10-2011, 08:30 PM   #15
They are:
Does my MAF meter need to be calibrated to these? I wouldn't think so since there basically stock.
Old 07-10-2011, 08:31 PM   #16
There getting changed soon anyway.
Old 07-10-2011, 09:23 PM   #17
Re: Injector size?
No, there is not enough difference between these and the factory injectors to worry about.
08:25 PM
