got some new heads cam question - Mustang Evolution
Old 07-10-2011, 09:10 PM   #1
workmail21's Avatar
I just got a set of gt40p heads rebuilt and machined I was wondering would a trickflow stage one or two cam work with these heads or is there something better out there its my DD but i still wanna take it to the strip some times and my budget is 300?
workmail21 is offline   Reply With Quote
Old 07-11-2011, 09:05 AM   #2
Titus Wadicus
svtlx's Avatar
Re: got some new heads cam question
you got room in there to run a stage 1 with 1.6rr only. dont get greedy or you will be buying new hew heads and pistons.
if u run an alphabet cam... dont run larger than an "e"..... with 1.6rr only.
hope this helps...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-11-2011, 12:31 PM   #3
workmail21's Avatar
Helps alot thanks
Old 07-11-2011, 06:51 PM   #4
workmail21's Avatar
Do I need roller lifters too?
Old 07-11-2011, 07:54 PM   #5
Titus Wadicus
svtlx's Avatar
no, u already have those if u have an 86 and up 302
Old 07-11-2011, 08:27 PM   #6
Just to be safe you should check your piston to valve clearance before final assembly.
Old 07-11-2011, 09:09 PM   #7
workmail21's Avatar
Ok cool thanks for all the help guys
Cam install... stangstar92 1996-2004 Mustang GT 15 07-14-2011 10:34 AM
motor question workmail21 General Car Discussion 2 07-05-2011 11:04 PM
Stupid question Mustanglife General Mustang Discussion 3 07-04-2011 01:55 PM
cobra question vinnygt 1996-2004 Mustang GT 17 06-30-2011 08:50 AM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 09:30 AM
08:22 AM
