Rrverse lights - Mustang Evolution
Old 07-12-2011, 09:46 PM   #1
Qwik Four Six's Avatar
Rrverse lights
My reverse lights never have worked. I don't know if it was something when the previous owner did the motor and transmission swap or what. And the lights aren't blown..
Qwik Four Six is offline   Reply With Quote
Old 07-12-2011, 10:07 PM   #2
Jamesgt08's Avatar
Did you check fuses? Or wiring?
Jamesgt08 is offline   Reply With Quote
Old 07-12-2011, 10:14 PM   #3
If the previous owner replaced the auto for a standard or the other way, the plug for the back up lights is different from auto to standard due to the need of a neutral safety switch. Under the car there will be a plug from the car and one from the trans, just need to figure out the reverse lights wires and connect them.
Dexter is offline   Reply With Quote
Old 07-12-2011, 10:15 PM   #4
Re: Rrverse lights
Auto or manual?
Likely the switch that activates them when you put it in reverse.
Old 07-12-2011, 10:22 PM   #5
Manual.
Old 07-12-2011, 10:45 PM   #6
Re: Rrverse lights
Switch Location.
Name:	T5 Trans Switches.JPG
Old 07-12-2011, 10:58 PM   #7
So...do I need to buy a new one or what?
Old 07-12-2011, 11:07 PM   #8
Re: Rrverse lights
Take a look at it and make sure it is connected first.
You can test it with the wires disconnected if you have an ohmmeter.
Test the wires with a 12 volt test light to see that you have power to the switch.
Old 07-12-2011, 11:11 PM   #9
Alright man. I'll check tomorrow. Thanks.
Old 07-13-2011, 10:23 AM   #10
These two wires have conduit around them, they're seperate and they are tied onto the side of the tranny with a zip tie. They're not hooked up. One is red and one is blue.. What do they go to? Doesn't look like the could hook into each other but I'm not sure..
Old 07-13-2011, 10:36 AM   #11
Jamesgt08's Avatar
Them kinda look like o2 sensor connections. Thats not ur reverse light wire.
Old 07-13-2011, 10:37 AM   #12
Re: Rrverse lights
Can't really tell from the picture.
Did you find the switch and is it connected?
Old 07-13-2011, 10:39 AM   #13
Right. Damn I forgot about that.
Old 07-13-2011, 10:40 AM   #14
I found the switch. Is something supposed to connect to it.
Old 07-13-2011, 10:45 AM   #15
Re: Rrverse lights
Yes, it should be connected into the wiring harness.
I will see if I have a diagram of the wiring.
Old 07-13-2011, 10:46 AM   #16
Alright. Thanks.
Old 07-13-2011, 11:14 AM   #17
Re: Rrverse lights
Diagram.
Name:	89-93 Mustang Body Wiring.gif
Old 07-13-2011, 11:17 AM   #18
I'm confused. What's that to?
Old 07-13-2011, 11:18 AM   #19
I know it's a wiring diagram but is it for a wire cluster, or what?
Old 07-13-2011, 11:22 AM   #20
Re: Rrverse lights
It is the body wiring diagram.
Find the switch in the middle right, then it shows where the wires go to.
Click once to open the image, then click on it again to enlarge.
Old 07-13-2011, 11:37 AM   #21
I know about enlarging. But there's nothing that goes to the switch...no wires under the car for it or anything.
Old 07-13-2011, 11:46 AM   #22
Re: Rrverse lights
Then you will have to run new wires or replace the harness.
New Shifter.....No Backup Lights Now! jjsg09 1996-2004 Mustang GT 11 07-11-2011 05:18 PM
Lights? NYmustang5 Pre-2005 V6 Mustang 3 07-08-2011 01:43 PM
fast blinker - lights all good sattwood General Mustang Discussion 2 07-04-2011 08:01 PM
06:20 AM
