Hey guys i need help - Mustang Evolution
Old 07-16-2011, 06:21 PM   #1
Snappybadman's Avatar
So I have a 91 lx that I just did I motor and tranny swap on I turned it from an auto to a 5speed and now my tranny is messing up when u down shift it doesn't want you to go into the gears and it sounds like something is grinding when I go from 3rd to 4th please help
Snappybadman is offline   Reply With Quote
Old 07-16-2011, 07:26 PM   #2
Re: Hey guys i need help
Sounds like you either have a misadjusted or worn out clutch, or possibly a stretched cable.
Another possibility is worn synchros in the transmission.
Old 07-16-2011, 07:36 PM   #3
Loc: Austin,TX
Did you know the condition of the tranny before you put it in?
Old 07-16-2011, 07:53 PM   #4
Yeah it was in good shape when I bought it the guy sold me the motor and tranny both it was shifting really good then it started doing this and someone told me it might be the fork I put a new clutch in it when I swapped everything over
Old 07-16-2011, 09:26 PM   #5
Yes, it could be a bent shifting fork in the transmission if it doesn't have a positive stop aftermarket shifter and you have been "banging" gears pretty hard.
Old 07-16-2011, 09:46 PM   #6
Ok I'll check that out any other ideas about what it may be
Old 07-16-2011, 10:22 PM   #7
That should about cover it.
It is full of fluid isn't it?
Old 07-16-2011, 10:57 PM   #8
Yeah
Old 07-17-2011, 09:41 AM   #9
wereKEV's Avatar
It sure sounds like a bent fork if everything else is good.
wereKEV is offline   Reply With Quote
Old 07-17-2011, 11:03 AM   #10
Ok I'll check that out and see what's up would it make a grinding sound while in gear
Old 07-17-2011, 11:07 AM   #11
Yes it could because if it is bent then the gears are not being fully engaged, which can damage your transmission.
Old 07-17-2011, 11:08 AM   #12
Ok thanks for your help now the fun starts
Hey guys! I'm new to EV! 11CalSpecialGrl New Member Introductions & Greetings 41 07-22-2011 07:35 AM
08:21 PM
