Hey guys - Mustang Evolution
Old 07-19-2011, 08:45 PM   #1
90blue5.0gt's Avatar
Hey guys
Hey what would cause the fan to only blow alittle heat out even when the heats on it only blows alittle air how could I fix that please thanks for any info
90blue5.0gt is offline   Reply With Quote
Old 07-19-2011, 09:08 PM   #2
Re: Hey guys
If you are talking about air flow quantity then you may have problems with your fan motor or fan speed switch.
Old 07-20-2011, 07:38 AM   #3
Well maybe so because I would switch it on sometime for heat in the winter and it would not but switch it of an on then it will cut on I know where another ac switch panel thing so I will try it hopefully that's it
Old 07-21-2011, 05:33 PM   #4
Yeah I changed it and it was just the swith ok thanks all
Old 07-21-2011, 05:43 PM   #5
Re: Hey guys
Good, glad you got it fixed.
Old 07-21-2011, 05:58 PM   #6
Now just need to recharge the air conditioner I got it fixed once didn't use it for awhile and now it warm on air
Old 07-21-2011, 06:06 PM   #7
Re: Hey guys
If it is leaking off you may need some new hoses or hose seals (O-rings).
Old 07-21-2011, 08:02 PM   #8
Do you know how I could replace them and where an wich ones are most likely to go bad
Old 07-21-2011, 09:54 PM   #9
SleepingStang's Avatar
Most parts stores will sell you an entire kit. Some are for compressor and others for the spinglock lines.
SleepingStang is offline   Reply With Quote
Old 07-21-2011, 10:59 PM   #10
Re: Hey guys
You will have to replace all of them with a kit or take it to a mechanic and let them run the "sniffer" or "dye" over the lines to see what is leaking.
Old 07-22-2011, 05:08 AM   #11
Ok thanks
Hey guys! I'm new to EV! 11CalSpecialGrl New Member Introductions & Greetings 41 07-22-2011 07:35 AM
Figured you'd guys like this. Tippy Pictures and Videos 1 07-18-2011 04:29 PM
Hey guys i need help Snappybadman 1979-1995 Mustang GT 11 07-17-2011 11:08 AM
09:49 AM
