just curious - Mustang Evolution
Old 07-19-2011, 09:09 PM   #1
workmail21's Avatar
just curious
What kinda hp is my setup running I got a 5.0 with gt40p heads cold air intake shorty headers o/r h-pipe?
What will it be when I put in an e-cam and roller rockers?
Just curious as to how much power I've gained and am going to gain with the money I've spent in the last 2 weeks
workmail21 is offline   Reply With Quote
Old 07-19-2011, 09:15 PM   #2
Re: just curious
That's really hard to tell because there are so many variables.
You started with what 215 -225 HP stock?
I'd hazard a guess that your current mods added between 25 - 50 HP maybe, and you may pick up another 25 -50 with the cam and rockers if you get it tuned properly.
Real world gains hardly ever match what is claimed by various parts manufacturers. Most of their figures come from ideal installations, perfect tuning and conditions.
Old 07-19-2011, 11:42 PM   #3
workmail21's Avatar
Yea I figured I was just wondering ballpark sounds good just wondering what my 500 bucks is getting me
Old 07-20-2011, 07:56 AM   #4
Re: just curious
Horsepower is expensive and the higher you get the more expensive it is.
Old 07-20-2011, 08:45 AM   #5
stampde's Avatar
Re: just curious
i HAD AN 87 t-BIRD THAT I did that I basically did that to ,had a 93 Cobra short block GT40P heads ,slightly ported , E303 cam , 1.7 rockers , and long tubes , with an edelbrock intake , never dyno'd but figured in the 275 range , in a heavy t-bird it ran 12.70's with 3.73's ..............
2011 GT Auto
Old 07-20-2011, 07:01 PM   #6
Stang.racr's Avatar
Can't tell you a number but you will like the power of that e cam with them heads, what kind of intake do u got
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-20-2011, 08:11 PM   #7
workmail21's Avatar
Just stock yet that's the next thing im gonna get whats a good upper and lower intake to put with all that
Old 07-20-2011, 09:35 PM   #8
Re: just curious
A Cobra intake would be a good choice and probably one of the least expensive.
Old 07-20-2011, 09:53 PM   #9
Meansaleen's Avatar
I had gt40x heads e303 cam 1.6 rockers vortech upper lower intake bbk c.a.i Mac 1 5/8 shorty headers x pipe no cats flowmaster 2 chamber 24lb injectors with calibrated maf 190 lph fuel pump accufab throttle body everything ported and polished. I put down 280 rwhp. Without a tune. ( was dynoed before supercharger install for comparison) Hope this gives you an idea.
Meansaleen is offline   Reply With Quote
Old 07-20-2011, 09:57 PM   #10
Meansaleen's Avatar
Oops. Also had msd ignition system.
Old 07-20-2011, 10:05 PM   #11
bbunt302's Avatar
What's driving your decision to use the E-cam? There are much better cams on the market today for your setup.
Scary stuff.
Old 07-21-2011, 01:19 AM   #12
workmail21's Avatar
Someone said its the biggest I can go with stock pistons what's better that I could fit in there I wanna make the most power I can with out rebuilding the engine from the block up
Old 07-21-2011, 02:48 AM   #13
Re: just curious
Go here and punch in your combo - CamQuest
When it chooses the best cam for you, compare the specs against the E303.
Old 07-21-2011, 03:37 AM   #14
workmail21's Avatar
Cool thanks for the site ill check it out after work see that's something id never find with out this forum glad im a member
Old 07-22-2011, 07:30 AM   #15
workmail21's Avatar
Re: just curious
I went here and it said i gotta call is there anywhere else i could go to figure it out?
Old 07-22-2011, 10:21 AM   #16
Re: just curious
Did you put in all of the specifications it asks for?
I just ran it, guessing at some of your specs and it worked fine for me.
Here are the part numbers of the top three cams it chose.
Comp Cams:
35-514-8
35-310-8
35-304-8
Old 07-22-2011, 10:49 AM   #17
workmail21's Avatar
Yea I did ill try it again that's odd
Old 07-22-2011, 10:51 AM   #18
Las0mbra's Avatar
I'd just call them... Youll probably get a better answer
Old 07-22-2011, 05:55 PM   #19
bbunt302's Avatar
Biggest isn't always best. Give Comp a call and I'm sure they could recommend you a much better cam for your setup.
Scary stuff.
10:47 AM
