Does foxbodys have a knock sensor? - Mustang Evolution
Old 07-20-2011, 10:32 AM   #1
Stang.racr's Avatar
Sensor
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-20-2011, 10:46 AM   #2
Stang.racr's Avatar
I am thinking about a gear drive but a knock sensor can detect a knock and ****** timing to compensate, Ive talked to some folks that ran them but always forget to ask
Old 07-20-2011, 12:21 PM   #3
stampde's Avatar
Re: Does foxbodys have a knock sensor?
No Knock sensor !!
2011 GT Auto
Old 07-20-2011, 12:32 PM   #4
mustangbill00's Avatar
I ran a gear drive on my 95 GT with no problems! Do it!
mustangbill00 is offline   Reply With Quote
Old 07-20-2011, 01:49 PM   #5
FYI:
A gear drive will impart additional noise and harmonics.
A toothed belt drive will not, however they are more expensive.
Old 07-20-2011, 03:49 PM   #6
I got a lot of attention with mine but I don't think there really worth it unless you have a serious drag car IMO. There was no difference when I switched back to the chain.
Old 07-20-2011, 04:22 PM   #7
Some people buy them just because they like the gear whine.
They do however make "quiet" gear drives too.
Old 07-20-2011, 04:22 PM   #8
Stang.racr's Avatar
Yeah I just read that they didn't, I'm not so much doing it suspecting any power or nothing buy figured that 40% extra cash may buy something that woud last longer and be more precise
Old 07-20-2011, 04:28 PM   #9
They should last longer and be more accurate for sure and you should be able to set/adjust your cam timing easier.
I had a chain on an old 302 once that was so badly worn, when you put a timing light on it you could see it jump back and forth 6 degrees or more.
Like a D.A. I took it for one last drive and it failed about 15 miles out.
foxbody
1989 mustang motor knock kbolden50 1979-1995 Mustang GT 66 09-11-2011 09:10 AM
MAF sensor Mustanglife Pre-2005 V6 Mustang 5 07-01-2011 08:22 AM
03:20 PM
