Runs and dies - Mustang Evolution
Old 07-21-2011, 05:46 PM   #1
SportySpice's Avatar
Runs and dies
88 5.0
So it was almost 100 degrees today and i drove the car about 30 miles, shut it off for half hr and when i started it again it started hard and idled weird till i revved it. Driving for 5 mins it starts running rough and dies and did this about 5 times till i towed it home. Was it just too hot today? Ideas? Thanks
SportySpice is offline   Reply With Quote
Old 07-21-2011, 06:00 PM   #2
90blue5.0gt's Avatar
Probably the ignition module it may be doing it
90blue5.0gt is offline   Reply With Quote
Old 07-21-2011, 06:02 PM   #3
Re: Runs and dies
May be the pickup coil in the distributor.
Did you check your coolant level, oil?
Old 07-21-2011, 06:41 PM   #4
The was no coolant in the jug but the fluid that was in the radiator was a rust color? And i had just put some oil into it bc it burns it up, and sometimes oil pressure drops when i come to a stop but goes back to normal when i take off?
Old 07-21-2011, 07:43 PM   #5
Re: Runs and dies
The oil pressure drop is a sign of worn out main, rod & cam bearings and oil pump.
Burning oil is a sign of worn out rings and pistons.
The rust shows that the cooling system hasn't been flushed for quite some time. The coolant in the overflow tank should be up to the level indicated on the outside of the tank.
I'd say you are very close to needing a rebuild or new engine.
Old 07-23-2011, 08:52 AM   #6
stampde's Avatar
Re: Runs and dies
+1
but back to your problem , Ignition module or possibly fuel vapor lock
2011 GT Auto
06:42 AM
