Jus bought a 88 5.0 hatchback 5speed - Mustang Evolution
Old 07-22-2011, 11:33 AM   #1
choppa5307's Avatar
I jus got a foxbody so I'm new to the whole thing i want to get some power out of my 302 any suggestion and put in mind I'm a college student
choppa5307 is offline   Reply With Quote
Old 07-22-2011, 01:25 PM   #2
stampde's Avatar
Re: Jus bought a 88 5.0 hatchback 5speed
pics ???
is it stock ???
do the 10 minute tune-up , take the air box out ,remove the air silencer that goes into the fender , then re install the air box with a K&N Filter ,grab a timing light and advance the timing to *14 degrees initial , it'll wake right up !!!
thats if its stock ...........
2011 GT Auto
Old 07-22-2011, 06:01 PM   #3
choppa5307's Avatar
It's all stock I have about $1500 set a side fa parts
Old 07-22-2011, 07:30 PM   #4
What exactly do you want or expect out of your car?
Old 07-23-2011, 08:48 AM   #5
stampde's Avatar
WELL THEN, Cold air system , Exhaust and some gears ........ wont break you ,and it'll wake the car up ....... don't forget to advance the timing or have some one do it
2011 GT Auto
Old 07-23-2011, 08:56 AM   #6
austinknoll's Avatar
I'd say cold air, exhaust, spark plugs, plug wires.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-23-2011, 09:31 AM   #7
choppa5307's Avatar
Where I'm from we do alot of street racing how much will it take to get my car running close to mid 11s
Old 07-23-2011, 09:58 AM   #8
stampde's Avatar
mid 11's ??? you don't have enough $$$$$$$$$$$$ unless you spray it ( NOS )
2011 GT Auto
Old 07-23-2011, 10:09 AM   #9
choppa5307's Avatar
I was looking at a top end kit fa now and get it stroked later and would $3000 get me there
Old 07-23-2011, 12:38 PM   #10
It will get you close for a top end kit & NOS if you can do the work yourself, but you will need more $$ to stroke the engine too.
TFS Top End Kit - $2449.99
NOS Kit - $599.99
331 Stroker Kit - $1131.99
Old 07-23-2011, 02:38 PM   #11
Ur gonna spend about $5000 to get it in the 11s. I would just find stuff to make it more fuel efficient an less restrictive. And when I get enough put top end kits and NOS on it
65 Mustang coupe
Old 07-23-2011, 06:00 PM   #12
choppa5307's Avatar
Ok... Well would a 351 b better or trying to stroke my engine
Old 07-23-2011, 08:37 PM   #13
The 351W would be a better choice.
It has more cubes to start with and it is a much stronger base for a performance engine than the 5.0.
Old 07-23-2011, 09:25 PM   #14
wc3john's Avatar
I'd go for the 351. The torque difference for starters is crazy.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-24-2011, 09:36 PM   #15
choppa5307's Avatar
I found a couple of twin turbo kits on eBay between $900-1500 but ion kno anything about them
Old 07-24-2011, 09:53 PM   #16
For the most part, leave the eBay kits on eBay.
Substandard parts and shoddy manufacturing may end up causing you more damage than the discounted price you receive is worth.
See the sticky thread on Superchargers and Turbos.
Old 07-24-2011, 10:09 PM   #17
choppa5307's Avatar
Well wat kind of mods u suggest
Old 07-24-2011, 10:41 PM   #18
What do you want to do with the car?
I'd like a bored & stroked to 408 or 427 cubic inch 351W, with twin turbochargers.........but my pocketbook can't handle it right now.
Figure out what you want versus what you can afford or are willing to work toward and go from there.
That's what I did several (3) years ago and now I am within the purchase of 2-3 more items of having everything I need to complete my build.
Check out the tech articles at MM&FF for some ideas if you are likewise inclined on the 351W.
Old 07-25-2011, 12:47 AM   #19
choppa5307's Avatar
I want to have over 300 hp
Old 07-25-2011, 01:03 AM   #20
Then the Trick Flow top end kit can get you to where you want to be.
Old 07-25-2011, 11:44 AM   #21
choppa5307's Avatar
If I get the top end kit do I have to do something wit the bottom end
Old 07-25-2011, 11:59 AM   #22
If it is in good shape, no you do not.
Old 08-07-2011, 11:12 PM   #23
choppa5307's Avatar
If u had a stock 302 and have 2500 to spend what would u go wit first
Old 08-08-2011, 01:14 AM   #24
93slowstang's Avatar
I would definitely go fir the top end kit. It should put you around your goal.
Old 08-08-2011, 10:46 AM   #25
choppa5307's Avatar
What top end kit beside trick flow would u use
Old 08-08-2011, 10:55 AM   #26
5.slow's Avatar
Region: Delaware
The holly systemax is a good one, although I'm assuming you mean cheaper. You could always go with some rebuilt gt40 stuff and take your savings and do some exhaust work or numerous other things.
5.slow is offline   Reply With Quote
Old 08-08-2011, 03:33 PM   #27
Is there any downside to adjusting your timing? Would I need to get my car tuned? Could I go to Any local auto shop?
black.fox.93 is offline   Reply With Quote
Old 08-08-2011, 09:14 PM   #28
5.slow's Avatar
Region: Delaware
I'm wondering the same thing. I'm about to move mine but don't know if the rumors of needing higher octane are correct or not.
Old 08-09-2011, 01:06 AM   #29
You wouldn't need to have it tuned just by advancing your timing. No downside except it is preferred to run a higher octane to reduce the chances of pinging.
---------- Post added at 02:06 AM ---------- Previous post was at 02:05 AM ----------
Mine is at 15 right now.
Old 08-10-2011, 11:24 AM   #30
choppa5307's Avatar
Which gears would b better 3.73 or 4.11 gears
Old 08-10-2011, 11:38 AM   #31
Street - 3.73
Strip - 4.11
08:19 AM
