rear disc brakes swap - Mustang Evolution
Old 07-23-2011, 01:00 PM   #1
I have a 1993 notch with a 5 lug conversion and i want to go with disc breaks im just about to order the brembo 13inch 4 pistons for the front but i was woundering what the best way to swap the rear over to discs im not looking to go super cheap i want a good set a brakes but i also dont want to go over bord any advice would help alot thanks
wss003 is offline   Reply With Quote
Old 07-23-2011, 02:47 PM   #2
Re: rear disc brakes swap
You can swap the SN95 rear disc brakes on to a Fox Body.
The only drawback IMO is that you need to use the SN95 axles, which push the wheels out 1" on each side toward the fender.
Finding a rear disc brake kit for a 93 Fox Body has been very difficult.
I can find almost every other year without to much trouble.
The only thing I ran across during my search was this - Rear Disc Brake Kit on eBay. That listing is outdated but this guy may be able to help you find what you need. - Tech Parts Plus More
NOTE: You will need to upgrade your master cylinder & proportioning valve too when installing rear disc brakes, as the factory master cylinder will not supply enough fluid for rear disc brakes and the brake proportioning is different for disc brakes.
Old 07-23-2011, 04:08 PM   #3
Las0mbra's Avatar
The only drawback IMO is that you need to use the SN95 axles, which push the wheels out 1" on each side toward the fender and they are a 5 bolt pattern which will require wheel replacement or having the flanges holes welded up and redrilled for the 4 bolt Fox Body pattern.
OR, you can just get a kit - SSBC Disc Brake Kit which is much simpler.
He has a 5 lug conversion...
Old 07-23-2011, 08:16 PM   #4
Thanks, I didn't read it close enough the first time.
Correction has been made.
Old 07-23-2011, 11:48 PM   #5
Qwik Four Six's Avatar
Wait...how is the sn95 axle bad...doesn't it give you a wider stance..?
Qwik Four Six is offline   Reply With Quote
Old 07-24-2011, 12:21 AM   #6
Not "bad" & yes it does.
At the expense of limiting your wheel width.
They add .750" to 1.0" on each side to your rearend wheel mounting width.
I have read that this limits you to an 8" wheel width on the rear unless you want to modify the fender.
Old 07-24-2011, 01:46 AM   #7
93slowstang's Avatar
Or you can use your five lug axles in that rear end and buy the off set caliper brackets for it.
http://www.latemodelrestoration.com/...apter-Brackets
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
03 v6 rear brake help TaylorF25 General Mustang Discussion 2 07-11-2011 03:58 PM
No more engine swap Mustanglife General Mustang Discussion 4 07-07-2011 10:16 AM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 08:07 PM
03 v6 rear brakes TaylorF25 Pre-2005 V6 Mustang 8 06-25-2011 10:01 PM
04:11 AM
