its alive!!! - Mustang Evolution
Old 07-24-2011, 11:58 AM   #1
Titus Wadicus
svtlx's Avatar
its alive!!!
my 96 v6 to efi v8 conversion is alive!!!
i just started yesterday. i still have to put the pulleys and blower on it, but damnit it runs! im gonna attempt to upload a couple motor pics... check out how close the intake is to the firewall.. its tucked up under there..
ID:	29321   Click image for larger version
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-24-2011, 12:00 PM   #2
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
if you guys can see my profile pic, you will see that i snatched the set-up outa my 92 notch and droped it into this 96. and yes, 98% everything swapped straight over, even exhaust
Old 07-24-2011, 12:54 PM   #3
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
o yea, the v6 was t5 equiped so i left it in the car... i had to swap bell housing and clutch cable. i plan on using the 3.45 with trac-lok from outa my coupe as well.
the wiring harness portion was not all that complicated. the portion you need to swap over is relativley small, and is very "plug and play". you unplug the v6 engine and pcm harness, then plug in the v8.
i used a fox body based motor so there were sum concessions and re-engineering requried in sum instances. i.e. im running an independent electric fan, still running off of a sensor, just not through the factory fan computer.
i made sum spacers so i can run sn95 powersteering bracket with the fox body timing cover. i did this so i dont have to try to find an sn95 blower bracket for my powerdyne bd11-a. also, i can run a/c since now i have the compressor and all the lines specifically designed for the car (yay!).
the boxed rear upper and lower control arms swapped right over from my fox, as well as my v8 sway bar. i bought sum 2"drop springs since i was gonna be in there anyway.
ill take sum more pics since i figured out how to get them outa my phone.
Old 07-24-2011, 01:00 PM   #4
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
last but not least... the interior was saddle.... it's black everything now. came out freaking awsome.. pics soon to come.
Old 07-24-2011, 01:25 PM   #5
junoS197Bl08's Avatar
Re: its alive!!!
looks great dude, post some more pics of everything when its finished. How long did the build take u?
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 07-24-2011, 01:35 PM   #6
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
honestly..... several months. im not even sure on a timeline. i bought the car (the 96) in december, but i had to disassemble my 92 notch first.... then take the v6 outa the 96, build the v8.... a long a$$ time...lol.
Old 07-24-2011, 04:03 PM   #7
shaqfu's Avatar
Re: its alive!!!
very cool, cant wait to see
shaqfu is offline   Reply With Quote
Old 07-24-2011, 10:53 PM   #8
Re: its alive!!!
Nice! First time I ever saw a 96' 5.0.
Did you replace the V6 K-Member with a V8?
Is the driveline hooked up?
Just asking because it seems to be set back pretty far.
Old 07-24-2011, 11:31 PM   #9
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
6cyl and pushrod v8 share the same mounting demensions... so it dropped right in. i had to put v8 bell on the t5 and it all went together. all driveline and exhaust are hooked up. i think it just sits so far back cause itsa "split port style" type intake. it also has a 1" spacer to clear the valve covers and throttle bracket. it sits up pretty high, according to bbk a cobra r hood should fit it. it sits right under the firewall in the back, but the front is almost six inches over the fender....
not to mention it was originaly designed for a fox body
Old 07-25-2011, 12:53 AM   #10
Re: its alive!!!
I see, thanks for the info.
I'd run a limiter on the DS motor mount just in case.
Old 07-25-2011, 09:03 AM   #11
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
i run one of those anyway..lol. helps put the torque to the wheels, not the mounts...
Old 07-25-2011, 09:16 AM   #12
stampde's Avatar
Re: its alive!!!
is that an old BBK intake ??? "
haven't seen one of those in years ...........
2011 GT Auto
Old 07-25-2011, 10:02 AM   #13
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
no, not really. its the street intake, they make a bread box racing intake too. they came out with them 4-5 yrs ago i think. i was running a typhoon before... this one is waaay better.
Old 07-25-2011, 10:19 AM   #14
Re: its alive!!!
That intake is still being manufactured isn't it?
I always thought these were cool - BXR , too bad they no longer make them.
Now I want to try one of these - Pro-Flo XT
Old 07-25-2011, 10:40 AM   #15
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
yea, to my knowledge they do. my gf bought it for me from jegs for xmas a while back.
i love that bxr.. but for 1000k they priced themselves outa the market. (looks real similar to the bbk
i want one of those pro-flo too..lol. it's quite a bit cheaper than my bbk. but my bbk makes stupid torque, especialy with the blower and spacer
Old 07-25-2011, 10:48 AM   #16
wereKEV's Avatar
Re: its alive!!!
Very cool good job be sure to post pics when it is all done .
wereKEV is offline   Reply With Quote
Old 07-25-2011, 10:50 AM   #17
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
ima go out later and try to get sum pics of the saddle to black interior conversion
Old 07-25-2011, 11:07 AM   #18
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
here sum more pics of the closeness of the intake to the firewall as well as pics of the adapted foxbody throttle body and cable to sn95. i saw it done on an '01 with a 351 so i knew it would work somehow..lol.
ID:	29366   Click image for larger version
Old 07-25-2011, 11:54 AM   #19
Qwik Four Six's Avatar
I was gonna keep my 97 v6 and swap it over to a DOHC 4.6 or a good SOHC 4.6. But that was gonna be a good bit of money. Nice job though.
Qwik Four Six is offline   Reply With Quote
Old 07-25-2011, 12:04 PM   #20
Titus Wadicus
svtlx's Avatar
Re: its alive!!!
unfortunatley, the modular aftermarket hasnt gotten to the level of the pushrod aftermarket. it still cost considerably more to build a mod motor... dollar to dollar verses pushrod.... and horsepower per dollar verses pushrod.
« Carb | egr hole? »
06:22 AM
