problem - Mustang Evolution
Old 07-25-2011, 03:12 PM   #1
shawnpbigelow's Avatar
problem
Ok guys. I have an 89 302 and i can drive it all day before it starts to sputter and miss and die. If i let it sit for a while it will start back up and run again. I just changed the fuel filter and that didn't fix it. But it did run for a couple of days before doing it again.
shawnpbigelow is offline   Reply With Quote
Old 07-25-2011, 07:20 PM   #2
Re: problem
Next time it does that you need to see if you have adequate fuel pressure and fire to the plugs.
Old 07-26-2011, 10:38 PM   #3
93slowstang's Avatar
Sounds like your fuel pump might be starting to go out. Mine was the same way after I drove it a few hours.
Old 07-26-2011, 10:40 PM   #4
bradh2414's Avatar
Happened to my dads truck. He could start it and drive it down the road but after like a quarter mile it would die. Repeats. Fuel pump was shot.
bradh2414 is offline   Reply With Quote
Old 07-26-2011, 10:43 PM   #5
Yep! Sounds like a bad fuel pump.. mine just went bad a month ago.. good luck!
GT4ERIN is offline   Reply With Quote
Old 07-27-2011, 04:54 AM   #6
Thanks for the input everyone. someone told me that it could also be the ignition module. So i am in the process of changing that along with plugs and wires. Then i will tackle the fuel pump.
Old 07-27-2011, 05:45 AM   #7
90blue5.0gt's Avatar
Yea definitely do the pump mine was doing that it would run fine but lose fuel pressure which would cause mine to stall and I had my pump replaced 5months ago and I was like no way but the hose that gos from the sending unit to the pump that guy didn't replace so my hose was dry rotted and causing my pressure to leak but I replaced all that first like new distributor module plugs wires even computer thinking that might be it but it was a 1.29$ hose lol
90blue5.0gt is offline   Reply With Quote
Old 08-06-2011, 07:18 PM   #8
Well it is back on the road again. I changed the ignition mod and so far so good. Thanks for all the advice everyone.
Drivers side window problem bullitt1075 1996-2004 Mustang GT 3 07-20-2011 10:47 AM
CAI problem MustangGT02 1996-2004 Mustang GT 5 07-15-2011 01:50 PM
Cooling fan and AC problem, please help 95GTS 1979-1995 Mustang GT 4 07-08-2011 08:24 PM
audio system problem DTRJ04 Mustang Audio & Video 2 07-01-2011 02:09 PM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
12:58 PM
