got her running - Mustang Evolution
Old 07-25-2011, 07:54 PM   #1
got her running
Finally got it running good.it was overheating . Does anyone have a guess of what cam is in there?I bought the car from someone who bought it from someone etc.the motor supposedly has a lot if money in it.but you never know until you take it apart which I haven't done yet. .
Old 07-26-2011, 08:25 AM   #2
Re: got her running
Hard to tell just listening. Maybe an E303 or similar?
Old 07-26-2011, 09:52 AM   #3
It was done on my phone.not the best quality.my guess was e303 also
Old 07-26-2011, 10:33 PM   #4
93slowstang's Avatar
Sounds more like the b cam. The e cam isn't that choppy.
Old 07-29-2011, 08:20 PM   #5
Can I check the cam size by putting a dial indicator on top of the roller rock directly above the push rod? That should at least tell me the lift and then I could cross ref that to common cams
Old 07-29-2011, 10:21 PM   #6
Re: got her running
No, not with a hydraulic lifter and lobe lift is not the same as valve lift.
Old 07-30-2011, 10:44 AM   #7
Oic i thought that cams were rated in how much left lift they produce.is there any other way to check?
Old 07-30-2011, 12:07 PM   #8
Re: got her running
You have to check the lift of the lobe directly on the camshaft, which would entail removing the intake manifold and rocker arms, pushrods & lifters for one cylinder to gain access to the camshaft lobes.
Then you would have to set up a dial indicator through the lifter bore on the lobe and zero it out on the base circle of the camshaft lobe you wish to check. Once zeroed, rotate the engine in its normal direction and record the highest lift reading from the dial indicator. Multiply that reading by your rocker arm ratio and you will have the valve lift number.
Old 07-30-2011, 12:43 PM   #9
Probably not worth the hassle.I know my motor is mildly built.but someone else built it so I don't exactly know what is in it.I appreciate the great advice and knowledge as always.
Old 07-30-2011, 01:22 PM   #10
Re: got her running
Not really worth it I agree.
You are welcome.
Old 08-28-2011, 05:09 PM   #11
I put a gear drive in there today. pulled the numbers off of the cam gear and it is a b303 cam
Old 08-28-2011, 05:12 PM   #12
Nice to know I can still tell the sound of a certain cam...lol
---------- Post added at 06:12 PM ---------- Previous post was at 06:11 PM ----------
It's a good N/A camshaft.
Old 08-28-2011, 05:18 PM   #13
Yeah, that was an excellent guess.The summit gear drive sounds great by the way.
Old 08-28-2011, 05:24 PM   #14
Is it loud or do you have the quieter one?
Old 08-28-2011, 05:45 PM   #15
Got the noisty one.I love the way they sound
Old 08-28-2011, 05:51 PM   #16
I had planned on getting one when I did my h/c/I swap but I didn't think I could handle the loudness. After I finished I realized they made quiet ones.
Old 08-28-2011, 05:57 PM   #17
I don't think the noisy summit one that I got is as noisy as a Pete Jackson or other top brands but its just right for me.
Old 08-28-2011, 07:02 PM   #18
That's cool, you need to post a vid up of it. The ones I heard damn near drowned out the exhaust.
Old 08-28-2011, 07:05 PM   #19
i made a video on my phone but it kinda distorts.ill try again and see if i can get it on here.
Old 08-28-2011, 07:07 PM   #20
That would be sweet.
Old 08-28-2011, 07:48 PM   #21
Re: got her running
Cover the microphone with a small piece of foam.
That will help block out wind noises and other external sounds you don't want.
Old 08-28-2011, 08:03 PM   #22
---------- Post added at 09:03 PM ---------- Previous post was at 08:58 PM ----------
thats a good idea.i recorded from further back and that helped to.
Old 08-29-2011, 03:09 PM   #23
hope this one is a little better.i tried trojans technique.
Old 08-29-2011, 04:07 PM   #24
A little too loud for me, but stills sounds good.
Old 09-04-2011, 07:39 PM   #25
Re: got her running
Sounds good!
A little loud like 93slowstang says, but it is sitting in a garage too, so I'd expect it will quieten down a bit outside.
Old 09-04-2011, 08:12 PM   #26
Region: Iowa
I like it, I'm planning on doing the same to mine but with the quiet stuff, just because my wife isn't a fan of too much loud
Bensfoxbody is offline   Reply With Quote
Old 09-04-2011, 09:01 PM   #27
When your in the drivers seat and the hoods down you can only hear a little but I like the sound.
Old 09-04-2011, 09:05 PM   #28
Region: Iowa
Im pretty new to fords, do our cars not have knock sensors?
Old 09-04-2011, 09:22 PM   #29
No knock sensors on the 5.0.
Old 09-04-2011, 09:29 PM   #30
Re: got her running
The older Fox Body Mustangs do not have them.
From what I can find online, they started using them on Mustangs in 1995.
Old 09-04-2011, 09:54 PM   #31
Not on the mustang sir, on the other 5.0 equipped vehicles though.
Old 09-04-2011, 10:48 PM   #32
Re: got her running
That's weird, the auto parts warehouse lists them for the 95?
1995-1998 Ford Mustang Knock Sensor - Motorcraft
Maybe they mean 96-98 and it is just a typo?
Old 09-04-2011, 10:50 PM   #33
I believe so, I know the 5.0 f150 has one, my buddy bought one for his 95 but found out he didn't have one on his car.
Old 09-04-2011, 11:02 PM   #34
Region: Iowa
Awesome! That leaves problem free usage for the gears then
94 mustang gt is running hot!!! 94 GT 1979-1995 Mustang GT 20 07-01-2011 02:45 PM
03:14 PM
