Newbie - Mustang Evolution
Old 07-27-2011, 12:29 PM   #1
Im new to the site and ford always been a enemy guy but just sold my bike and bought a 95 gt convertible . Has cold air system short headers with xpipe flowmaster mufflers and not cats. Has underpullies and ac removed with a pulley in place . Car idles re bad like it has a extreme cam. I would say up to 2500 it has no ump. Exhaust smells like a 70 chevelle real rich . I have been reading and I changed the egr valve but no change . Removed the vacuum line from the egr and it idle smooths out but real power under 2500 any ideas would BW great . Check engine does not go on only goes on when u punch it hard and then goes out when u let up. If u drive normal no check engine light any ideas would be great
tbonestang is offline   Reply With Quote
Old 07-28-2011, 05:16 PM   #2
You need to hook a scaner up and take it down the road, check everything out on the scaner, check fuel pressure, and regulator for fuel problem
C4king is offline   Reply With Quote
Old 07-28-2011, 05:40 PM   #3
SleepingStang's Avatar
Plus 1. Hooking up a scanner would be your best bet. Most auto stores now will loan you the scanner to check things out.
SleepingStang is offline   Reply With Quote
Old 07-29-2011, 03:54 AM   #4
Thanks checked all the local places and they only have ones for later models cars had to order one.
Old 07-30-2011, 06:16 PM   #5
No code at all I'm thinking the numb skull did tighten anything all the header bolts were loose . Gonna change the gaskets in the morn an put some real header bolts I'm with the Allen key in the middle to lock them in
Old 07-31-2011, 06:46 PM   #6
Got a 334 code today so I replaced the erg position sensor so now I'm at aloss and the sea foam did nothing
Newbie , Questions on moding a 2004 mustang demo214 Pre-2005 V6 Mustang 16 08-12-2011 04:59 PM
New Edge Newbie :) melissarblevins New Member Introductions & Greetings 12 07-30-2011 09:34 AM
newbie with 98 cobra procharged Richtq 1996-2004 Mustang GT 1 07-26-2011 07:06 PM
Newbie Versus Member avengnd ME Site Help & Announcements 19 07-15-2011 06:18 PM
01:58 AM
