little problems in the fox. - Mustang Evolution
Old 07-27-2011, 01:15 PM   #1
Frustration. I put the 351 in my 82 fox and I have the smallest belt possible that will fit on my car but after a few min of running the belt flies off. Any ideas I need some help
82stang224 is offline   Reply With Quote
Old 07-27-2011, 02:09 PM   #2
Brett Greene's Avatar
Loose pulley?
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 07-27-2011, 02:24 PM   #3
Stang.racr's Avatar
That or the pullys are not lined straight
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-27-2011, 02:32 PM   #4
Plus 1. Deff something wrong with the pulleys
Old 07-27-2011, 02:53 PM   #5
Re: little problems in the fox.
Take a piece of string or a straight edge if you have one long enough and check your pulley alignment.
Name:	Pulley - Sheave Alignment.jpg
Old 07-27-2011, 03:06 PM   #6
Thanks for the help I will defiantly look at that when I get home
Old 07-29-2011, 01:12 AM   #7
Harmonic balanced bolts worked their way out and I didn't notice a little mistake I will try a bit longer bolts. Cause this harmonic balancer is jacked up lol previous owner thought it would be cool to ghetto rig. When I get the money I will get a new one
Old 07-29-2011, 02:04 AM   #8
Glad you found the problem.
Replace the balancer before you run the engine much if it is damaged.
It can cause a lot of problems if it is out of balance.
Old 07-29-2011, 11:02 AM   #9
Well the threads are messed up. But I don't think that would effect the weight any
Old 07-29-2011, 05:31 PM   #10
Then run a thread tap through the holes to restore the threads as much as possible and use some Blue Threadlocker on the bolt threads to help keep them tight.
Old 07-29-2011, 06:11 PM   #11
Well I got it all fixed now lol
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Looking at trading the fox Qwik Four Six FYI Ads | Recently Listed 13 07-14-2011 11:36 AM
opinions on color for 88 fox 04TRV6 1979-1995 Mustang GT 39 07-08-2011 12:30 AM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
06:06 PM
