95 Gt cutting out! - Mustang Evolution
Old 07-31-2011, 03:11 PM   #1
95 Gt cutting out!
When I hit 2000 rpm it cuts in and out. It makes it tuff when taking off but once I get to 4th and 5th gear it quits. What in the hell is wrong with it?? I tried to get autozone to run diagnostic and they can only go back as far as 1996.
95GT is offline   Reply With Quote
Old 07-31-2011, 03:38 PM   #2
Re: 95 Gt cutting out!
Has to be either fuel or ignition issues.
Do you have any aftermarket ignition parts on it?
Is your fuel pressure ok (38-40 psi)?
Have you tuned it up recently?
Any further information you can provide will be helpful in making a diagnosis.
Old 07-31-2011, 03:55 PM   #3
I put new plugs and wires, cap and rotor about 4 months ago. It idles fine im not sure on the fuel pressure.
---------- Post added at 03:55 PM ---------- Previous post was at 03:54 PM ----------
I went with stock parts except the cap and rotor is Msd
Old 07-31-2011, 03:57 PM   #4
Check your fuel pressure and see what it does when you give it some gas.
You may have a pump or regulator failing.
Did you change the fuel filter?
Old 07-31-2011, 04:07 PM   #5
On my way to get a fuel filter
Old 07-31-2011, 04:24 PM   #6
Beav's Avatar
Good place to start...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 07-31-2011, 04:39 PM   #7
Anyone know if its Obd1 or Obd2?
---------- Post added at 04:39 PM ---------- Previous post was at 04:26 PM ----------
It has obd2 port but the scan tool dosent work. Wtf
Old 07-31-2011, 05:21 PM   #8
jhagan1980's Avatar
It's 1
jhagan1980 is offline   Reply With Quote
Old 07-31-2011, 05:41 PM   #9
Its 1 with obd2 port??
Old 07-31-2011, 05:50 PM   #10
jhagan1980's Avatar
Yes the 2 port does not work until 96 I believe
Old 07-31-2011, 06:48 PM   #11
Well I can rule out the fuel filter
---------- Post added at 06:48 PM ---------- Previous post was at 06:46 PM ----------
How do I get the damn thing read then?
Old 07-31-2011, 06:48 PM   #12
I didn't know that. Learned something new today.
There must be some adapter or some other way to scan them.
A mechanic in my area scanned the 95 GT I had.
Old 07-31-2011, 06:51 PM   #13
Where are you in Missouri?
There is a guy outside of town (Fayette) here that has a transmission shop and he scanned mine for me.
I'm pretty sure he used a Snap On scanner to do it with.
Old 07-31-2011, 06:54 PM   #14
jhagan1980's Avatar
There is a connector on your passenger wheel well towards the firewall. You have to jumper it and turn the key on to pull codes.
Old 07-31-2011, 07:01 PM   #15
Im in the springfield area. I took it to autozone and oriellys and they both connected it under the dash up by the hump
Old 08-01-2011, 05:23 AM   #16
bigcolt45's Avatar
You should probably have a shop use a scan tool that identifies the exact car.... Those years are more like obd 1 and a half ....very limited on data and more like obd 1 than 2
---------- Post added at 11:23 AM ---------- Previous post was at 11:22 AM ----------
My 89 is doing the same thing so im hoping you find an answer ....
bigcolt45 is offline   Reply With Quote
Old 08-01-2011, 12:26 PM   #17
Does the missing problem occur when the car is cold, hot or both?
Possibly there are issues with the pickup coil in the distributor, but they are usually more prevalent at higher operating temperatures.
Old 08-01-2011, 02:10 PM   #18
I took it to Ford will know something tomorrow.
Old 08-01-2011, 03:14 PM   #19
Let us know what you find out.
Old 08-01-2011, 05:27 PM   #20
Beav's Avatar
I'm guessing it is weak spark, maybe a bad coil wire, coil, or something in the distributor...
Old 08-02-2011, 02:00 PM   #21
They claim that the mass air flow plug was loose. I haven't picked it up yet. I will test it out and let y'all know.
Old 08-02-2011, 02:36 PM   #22
Beav's Avatar
At least that should be a cheap fix...
Old 08-02-2011, 03:29 PM   #23
43$ and a zip tie and its all better lol
Old 08-02-2011, 04:20 PM   #24
The electrical connection plug to the MAF?
Glad you got it fixed.
Old 08-02-2011, 04:27 PM   #25
That it was
CPO Mustang 2010 GT Premium ??? wickerman 2011-2014 Mustang GT 14 07-11-2011 10:57 PM
I need opinions..02 GT like new! shazzsk89 General Mustang Discussion 22 07-04-2011 07:17 AM
What does it cost to supercharge a 2012 gt at a ford dealer? I have a GT on order. brickcart 2011-2014 Mustang GT 36 07-02-2011 09:16 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
01:39 PM
