Egr valve and evr - Mustang Evolution
Old 08-01-2011, 09:03 PM   #1
Egr valve and evr
Where is the evr and does anyone have a pic of the proper way the Egr evr vacuums hose and where they go. Also if I go Egr block off what do u do with the evr
tbonestang is offline   Reply With Quote
Old 08-01-2011, 10:40 PM   #2
I think this is from a 94-95 5.0l.
Old 08-02-2011, 04:50 AM   #3
Thanks I have the diagram but I can't seem to find it in the engine department
Old 08-02-2011, 06:36 AM   #4
93slowstang's Avatar
It should be mounted on the back side of the passenger strut tower.
Old 08-02-2011, 06:42 AM   #5
There you go, it wouldn't let me load the pic a minute ago.
Old 08-02-2011, 08:15 AM   #6
Thanks for the info but it's a 95 so i think it's different
Old 08-02-2011, 08:26 AM   #7
It's identical except your cap is probably black. It should still be mounted in the same spot.
Old 08-02-2011, 03:54 PM   #8
Not there there is no even wire to plug it into , I'm thinking it's under the fender and ahole who owned before me had no idea what the hell he was doing
Old 08-02-2011, 05:58 PM   #9
Re: Egr valve and evr
Here are a couple of diagrams that may help.
Name:	94-95 Mustang Engine Bay.jpg
ID:	29796   Click image for larger version
Name:	94-95 Mustang Vacuum.jpg
Old 08-02-2011, 06:02 PM   #10
From what I've read some cars did have them under the rh fender. Just pull the fender skirt off and take a peek. My buddies 95 gt has his in the same location as mine.
Old 08-02-2011, 06:04 PM   #11
All the stuff from the strut tower is gone I telling you he was like egor from Frankenstein just kept cutting and thank
Old 08-02-2011, 06:13 PM   #12
I feel ya on that. I spent most of my money on missing parts just get mine running right. A lot of spliced wires from the plugs that were cut. Now I'm working on deleting most of it again.
Old 08-02-2011, 07:11 PM   #13
I would upload some pics but I don't know how
Old 08-02-2011, 07:20 PM   #14
If your on your phone whenever you go to reply click on attachments to upload a photo.
Old 08-02-2011, 08:23 PM   #15
Well I found it it's under the fender and there is a red and green tubes that run in to the engine dept but there cut and I have no idea where the vacuum should come from I'm guess where the idiot had the egr plugged right into
ID:	29798   Click image for larger version
Old 08-02-2011, 08:26 PM   #16
I posted a vacuum diagram for you a few posts up from here.
Old 08-03-2011, 03:24 PM   #17
Well on track now the idiot when he removed the ac he pulled all the vacuum hoses off it appears the vacuum off the back ofthe manifold feed the eve and ac which he did not know so I need to get some small hoses to reroute or just do the egr blockoff which I already ordered the plate and used my old sensor now since the car has no cats I don't need the air pump and stuff from what I can tell right guys
Old 08-03-2011, 05:14 PM   #18
If your talking about the smog pump then no, you don't need it.
Old 08-03-2011, 05:59 PM   #19
Well all that stuff and the ac are getting pulled out tonight
12:27 AM
