Whos using what chips - Mustang Evolution
Old 08-02-2011, 02:56 PM   #1
Who's is using wHat chips I want to fix that dam 95 timing ****** with out having to change the timing
tbonestang is offline   Reply With Quote
Old 08-02-2011, 03:02 PM   #2
93slowstang's Avatar
Sct with bama tunes loaded in it right now.
Old 08-02-2011, 03:14 PM   #3
That's a bit costly I have a old ball and chain and 2 rug rats and 360 is a bit steep
Old 08-02-2011, 03:25 PM   #4
Lol, I have three and told the wife I needed it to get my car to run right after the h/c/I swap.
Old 08-02-2011, 04:43 PM   #5
Re: Whos using what chipa
No chip for me, I scrimped and saved until I could buy an AFM PMS to tune my 86 GT.
Now if I can just manage to get enough cash together to purchase the last few parts I need to complete my SC install, I might actually get to use it.
Old 08-02-2011, 05:48 PM   #6
I know how that feels. I saved up and bought parts for over a year before I was able to enjoy them installed on my car. I'm still not done.lol
Old 08-02-2011, 06:08 PM   #7
Mustangs can be never ending projects for sure.
Note: If your car is an auto trans, which I assume it is since you are talking about the timing ******, you may want to give some thought to building the transmission up a bit before removing the ****** function. Ford built that in to protect the transmission which is to weak in its stock form to handle full power shifts for very long.
Old 08-02-2011, 06:10 PM   #8
5spd and I thought they all did
Old 08-02-2011, 06:27 PM   #9
I don't believe the 5-speed cars had that issue.
Old 08-02-2011, 06:42 PM   #10
94-95 they all did
Old 08-02-2011, 07:18 PM   #11
Re: Whos using what chips
94-95 they all did
Really?
In the AODE it was activated through the electronic transmission controls.
How did they activate it on a manual transmission car?
Old 08-02-2011, 07:27 PM   #12
Well I have 95
Old 08-02-2011, 07:32 PM   #13
Really?
It is based off of rpm and engine load.
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
Well I have 95
Looks good.
Old 08-02-2011, 07:34 PM   #14
Well I have 95
Nice!, I had one too.
Mine was an auto and you could feel it "lay down" right before a shift.
I have rode in and drove several manual transmission versions and I never noticed any drop in rpm or performance when shifting the manuals.
Old 08-02-2011, 07:47 PM   #15
Here's a write up for it.
http://webpages.charter.net/darrell1/mustang_efi.html
Old 08-02-2011, 07:54 PM   #16
Thanks!, I found this too.
Another thing the '94 -'95 cars do with spark is ****** it during a shift. The
automatic cars REALLY pull out the timing, but the 5spd cars do it also. Inside
the 5spd EEC calibration is a thing called Tip-in ******. Any time the throttle is
moved from a more closed position to a more open position, it can pull out some
timing. When you shift a 5-speed car, most people lift off the gas during the shift.
The EEC senses this, and when you push on the gas again it pulls some timing out.
So, if you "power shift" without taking your foot off the gas pedal it shouldn't pull out any timing.
Old 08-02-2011, 07:59 PM   #17
Guess not.
Old 08-02-2011, 08:41 PM   #18
Guess not.
Thanks, you have helped me learn a bit more about Mustangs today.
I appreciate it.
Old 08-02-2011, 09:52 PM   #19
I appreciate it.
And I've learned a good bit from you as well.
Old 08-02-2011, 11:14 PM   #20
GTtopgear's Avatar
Isn't worth it to dyno it instead ?
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 08-02-2011, 11:27 PM   #21
A dyno tune is always the best option if you have a shop close by and you can afford it.
Old 08-02-2011, 11:55 PM   #22
+1, especially if you already have a chip or pms already installed.
« cars back | Trans »
Has anyone heard of Gforce chips KINGCOBRA01 Pre-2005 V6 Mustang 16 06-29-2011 08:35 AM
04:42 AM
